rough idle 305 TPI HELP!
Old Sep 20, 2007 | 10:31 PM
91chevyz28's Avatar
Car: 1991 Camaro Z28
Transmission: 5 speed
Axle/Gears: alunimum drum limited slip 3.08
the car is a 91 z28 w/ a 305 5speed.the car starts fine but when it warms up (close loop)the idle is rough like it has a mild cam.when i hit the throttle the car bogs and then it revs up.the fuel pressure does not drop when i do this.i've replaced the following:
cap and rotor
spark plug wires(MSD 8.5)and plugs
o2 sensor
MAP sensor
TPIS
removed throttle body & IAC cleaned w/ throttle body cleaner
fuel filter
have steady fuel pressure
sprayed intake base for leaks
checked cat to see if it was clogged ran car w/ open pipe did same thing
any ideas would be a BIG HELP!
Jason
Old Sep 20, 2007 | 11:42 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Re: rough idle 305 TPI HELP!
Is it throwing any codes?
Old Sep 21, 2007 | 02:47 AM
fran_astur's Avatar
Car: 91 Trans Am, 73 Camaro
Engine: 305 TPI, 400 sbc
Take attention at the advance timing, not only set the initial timing at 6º BTC, also look what happen when you reconect the test wire. At this time the advance should be about 16-20º.
Old Sep 21, 2007 | 06:07 AM
91chevyz28's Avatar
i forgot to mention no codes are showing.when you say check the advance should the wire be connected or disconnected? I did check the timing,it was @ 10 degrees were i set it.
Jason
Old Sep 21, 2007 | 02:42 PM
91chevyz28's Avatar
sorry,just noticed you wrote w/ wire connected.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
