Bad ECM?????
Old Mar 4, 2001 | 04:54 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Bad ECM?????
OK, as in my previous posts below, my car has a bad stumbling problem. I have replaced:
-fuel filter
-MAP(checked it also)
-TPS(checked it also)
-checked injectors
-plugs
-wires
-cap/rotor
*Since all this stuff it still throws code 22...TPS. Its set a little higher at WOT but that shouldn't matter should it. The car also acts weird while driving on interstate. It almost acts like its stuttering on light load applications. After driving like this for awhile, cuty driving is horrible. I'm gonna put a new fuel pump in this week regardless of whether or not its bad. It needs one soon anyways (143k miles) and I figured it would be 1 less thing to worry about.
*** Could a bad ECm or one on its way out be causinbg this nonsense? TIA
'91 GTA:
www.fbody.com/members/91WS6GTA
Old Mar 4, 2001 | 04:55 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
It also cuts out at high rpm's sometimes. Fuel pump? COuld O2 sensor be making it bad too? thanks
'91 GTA:
Old Mar 12, 2001 | 09:30 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
No one??? Please help!
'91 GTA:
Old Mar 12, 2001 | 10:43 AM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Something I forgot on your other post, do you have a fuel pressure gauge you can hook up and lay on the windshield and drive around with to be sure you are getting the correct fuel pressure? Should start off around 45psi with vac line off, connect the vac line and it should drop about 10 psi.
Just to test that your getting enough fuel, I would run it with the vac hose off and the pressure should stay static at 45psi all the time, just as a test, and see if it still cuts out or is worse, that will maybe clue you in if it is actually a fuel problem.
If the fp doesn't stay at 45psi, then you may have a fuel problem, if the problem goes away, then you have a fuel problem.
Just some easy things to try...
Old Mar 12, 2001 | 11:58 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
THANKS alot man!! You guys are wonderful!! I just want to drive it again soon
'91 GTA:
Old Mar 12, 2001 | 05:24 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
If you're still having a TPS code, check the voltage at the TPS to make sure it's .54 volts at idle, then chack to see if it gets progressively higher until WOT (a friend helps here). If not you've got a bad sensor. Should be over 4 volts at WOT. That means you obviously have voltage to the TPS. There's 3 wires; a 5 volt supply wire, a reference (return voltage)wire, and a ground. Look up the reference wire at the ECM, and check with the ignition on by back-probing. DONT cut any wires. If you splice, seal the wire with liquid electrical tape. Compare with your TPS idle reading at the sensor. Should be relatively close. If there's no voltage, the ECM isn't getting the TPS signal, which would explain your problems. If the signal is off by a considerable amount, then there's resistance. Check the ground and then make sure the reference wire isn't cut or grounded. If that all checks OK, then start looking toward the ECM; make sure it's not a wiring problem first. Make sure the terminals on the TPS connector are OK, too.
Old Mar 12, 2001 | 07:17 PM
kens91's Avatar
I had a VERY similar problem in my '91 Z and it ended up being the PROM. Actually, it the PROM was so bad that it fried the computer, so I'd get someone to check the computer and PROM out before I throw too much more money into it. I spent about $500 on fuel pump, sensors, injectors, pretty much anything and everything that it could be. Make sure you have someone check the PROM, because one of the things that I did was get a new computer, but it didn't help because the PROM was bad, then the PROM fried the new computer. So be sure to check them both out.
ken
Old Mar 12, 2001 | 07:44 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Thanks! i'll try the PROM and ECM.
'91 GTA:
Old Mar 12, 2001 | 07:46 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
KENS91-
What symptoms did you have? 5-speed? Any codes? What exactly did your car do? THANKS
BTW- How do I get my PROM or ECM checked out?
'91 GTA:
skeltor
Feb 2, 2016 10:37 AM
88rscamar0
Sep 23, 2015 09:08 PM
Billy Decker
Sep 4, 2015 03:46 PM
willyjoejr
Sep 3, 2015 09:26 AM
RyanJB
Sep 2, 2015 01:27 PM
