HELP - new motor runs but...
Old Mar 16, 2001 | 10:58 PM
Aaron's 87's Avatar
I've got what sounds like a rich rolling condition.
This is the first time I've started the new motor. I have great heads, edelcrap high flow base and runners, SVO 24# injectors, 218/226 510/510 114LSA cam, and 355 cubes. I have to modulate the throttle to get it started and then keep a little on the throttle to keep it alive. It runs up to ~1500 rpm, drops down to ~900, almost dies, throws a quick SES, and revs back to 1500, and over again.
I set my chip for 26# injector constant. Timing is 4 adv when it almost dies and runs up to 30 adv when it revs up. Base timing does not affect the condition. Took out a bunch of turns off the AFPR, which moved the rolling range down a couple hundred rpm. Of course, my AutoXray is not connecting and the quick SES flash is not storing a code. Car smells rich.
I'm going to buy a fuel pressure guage tomorrow to see if I'm in the ballpark. I'll also check for vacuum leaks with a butane torch. I thought the chip may not be working, but it's not throwing a code.
Any other suggestions? I'm fried and barely thinking straight. Thanks for the help.
Old Mar 16, 2001 | 11:47 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
Are you still running the MAF?
Old Mar 17, 2001 | 07:43 AM
Aaron's 87's Avatar
Yes
Old Mar 17, 2001 | 01:23 PM
ONEFINE8T9's Avatar
<font face="Verdana, Arial" size="2">I'm fried and barely thinking straight. </font>
lol drugs are bad mmmmkay
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Mar 17, 2001 | 03:15 PM
Aaron's 87's Avatar
Not drugs - fumes from exhaust!
eightsixseven
Dec 16, 2024 01:50 PM
jhawkeye
May 25, 2022 06:33 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Elliswon
Aug 10, 2015 12:33 PM
squiggy2
Aug 9, 2015 09:30 PM
