Cam and rocker question
Old Mar 19, 2001 | 09:27 AM
90 Z28SS's Avatar
I won't be doing my motor till this fall and Im just looking for cheapie stuff to do to it in the mean time so I can save for all the new stuff . Will I gain anything at all with a stock LT1 cam . All it will cost me is gaskets , which I have already so it will be free . I'm not sure of the specs on the LT1 cam and my heads , cam and TPI unit are all factory stock and I do have the 5.7 motor . I'm just a tenth away from the 12's so even if gains are minimal I would go ahead and do it .
Also can I put 1.6 rockers on without changing the valvesprings . Will the stock LT1 valvesprings work ok .
Thanx for any help guys And remember I'm not looking for optimal I just need a couple tenths to get me in the 12's and the parts are free
Derek 90 IROC 5.7
Mods: All the usual bolt ons , 2500 stall , 373's , SS hood , lotta reduced weight.
Best Et: 13.16@101
383 mini ram motor planned for next year .
[This message has been edited by 90 Z28SS (edited March 19, 2001).]
Old Mar 19, 2001 | 09:47 AM
Beefy89's Avatar
Depends on which LT1 cam you have.I've got a 96 part#12551705 .447/.459 lift 205/207 duration @.05 lsa 117 deg.I added ZZ3 springs part#10134358 (which might be the same as LT1 springs)with 1.6 roller tips just to be safe.I think the springs are like $33 or so.I had to replace the retainers also.The car runs better,but I haven't taken it to the track yet to see how much.
We need Perry Mason
Old Mar 19, 2001 | 10:03 AM
90 Z28SS's Avatar
The cam , springs and lifters are out of a late 95 Formula .
Old Mar 19, 2001 | 11:34 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The stock LT1 cam is nearly identical to the L98 cam with a little extra lift. It may run a little better, it may not. Since it's free (except gaskets and your time) then go for it. Personally i wouldn't go through a cam swap for such a slim chance of real gains. At best you'll see 10-15hp which is not gonna get you into the 12s.
...ed
sweet_87_iroc
Sep 25, 2015 10:01 PM
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
