Timing Degree?
Old Mar 19, 2001 | 11:41 AM
Kulkat 63's Avatar
Timing Degree?
At what degree should I time the 1985 Iroc?
Old Mar 19, 2001 | 12:09 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
There should be a table of info on the bottom side of your hood. You should found the static timing setting on this table.
For my '87 350 TPI, the factory static timing is 6*.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Mar 19, 2001 | 01:42 PM
Kulkat 63's Avatar
The Timing was ripped off by previous owner.
<font face="Verdana, Arial" size="2">Originally posted by doc:
</font>
theshackle
Sep 17, 2020 08:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
bamaboy0323
Sep 3, 2015 06:07 AM
cstrobel65
Aug 15, 2015 10:19 AM
bamaboy0323
Aug 15, 2015 07:20 AM
