TPI Vaccuum Lines?
Old Mar 16, 2001 | 07:04 PM
Iroc Detroit's Avatar
TPI Vaccuum Lines?
I've been wanting to replace vaccuum lines on my car for sometime now but i've noticed all the different sizes and materials . The EGR (I believe) has those small hard tubes with the rubber connectors and other lines have tee's and othe connections. My Question is does some company sell complete vaccuum hose kits like some sell gasket kits or do I have to go from parts store to parts store till I get everything I need?
1985 Camaro Iroc Z
305 Tuned Port Injected
Old Mar 16, 2001 | 07:42 PM
89FormulaL98's Avatar
I'd like to know that too!
i think i might have a vacume leak
89' Firebird Formula WS6 L98, MSD 6AL MSD Blaster, Hypertech chip, K/N filter cone,flowmaster 80 series, hypertech air foil, koni shocks, edelbrock trailing arms
more to come soon.....
Old Mar 17, 2001 | 08:53 PM
bird of spray's Avatar
I agree, i patched mine a couple of times those plastic lines get really brittle.I checked with the dealer, they called it the egr harness. Better yet i would rather eliminate what isnt needed. My 87 T/A is a one owner low mileage garaged orignal i would hate have to touch an older or more worn one.
Old Mar 18, 2001 | 04:36 PM
superz's Avatar
hey guys my lines got brittle and broke too, so i took them of and removed and saved the rubber tees and elbows, went to the hardware store and bought small aluminum tubing. you can bend it by hand and it matched the rest of my TPI. worked great and will never get brittle
Old Mar 18, 2001 | 06:59 PM
Jim's Avatar
Jim
Car: 85 Camaro
I spent two years looking for this same assembly. But you can rebuild the assembly for around $5. The plastic hose can be bought at Advanced Auto Parts, It is (5/32)emission hose I think. It should be on the tree with the pcv valves or in that general area. You may want to clip off a small piece before you go into the store to verify the size of this hose.
Old Mar 18, 2001 | 09:17 PM
superz's Avatar
yeah but if you put that plastic vaccum line back on it will just get brittle again. do like i did and use the aluminum tubing, i spent about one dollar and fixed all my lines. ya can't beat that.
Old Mar 18, 2001 | 11:30 PM
Hey SuperZ, whats that aluminum line actually for or which area of the hardware store is it in? (plumbing)
1985 Camaro Iroc Z
Old Mar 18, 2001 | 11:36 PM
Vader's Avatar
Jim,
Welcome aboard!
Good call. That plastic "hose" is actually plastic tubing, and is a thermosetting compound. As the plastic gets heated, it gets harder instead of softer (like theromplastic materials). If your local auto store doesn't have it, or you want it in a different color, you can also get it by the foot through many industrial suppliers. The rubber connectors and fittings are a little more difficult to find, but can be replaced if necessary. Usually the originals can be removed and reused by coating the ends of the tubing with gasket cement, or you can use short lengths of rubber hose and shrink tubing to make a clean and sealed installation.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 20, 2001 | 03:31 PM
superz's Avatar
i'm not sure what it is for, i use it for exhaust on my model cars and it worked great for my vaccum lines. it can be bent by hand easily. in our local ace hardware store it is next to the long pieces of threaded rod
Old Mar 21, 2001 | 08:08 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Just convert all your plastic tubing to acrylic (clear) like the fishtank hose. It wont rot like rubber or get brittle like plastic (might yellow after years though)
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
LT1Formula
20
Nov 14, 2015 12:02 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
