9 bolt rear end help
Old Oct 3, 2007 | 10:07 PM
88transam400tpi's Avatar
Car: 88transam/ 86 iroc-z/ 64 corvette
Engine: ta 400ci tpi/ iroc 327 / vette 327
Transmission: ta 5 speed/ iroc 700r4/ vette m-22
Axle/Gears: ta 3:42/ iroc 3:73/ vette 4:11
i recently bought a 86 t/a and it has a 9 bolt i was wondering if anyone knows what gears are likely to be in my car it is a auto 305 tpi i am building a motor for it now check out my other threat "engine build how much power"
Old Oct 4, 2007 | 06:54 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: 9 bolt rear end help
Most likely a 2.73 ir 3.27.
I believe mine had a tag on it that was stamped 3.27.
There is an unbeliveable post on the 9bolt here, I believe in Tech/General.
You might want to search there.
Ron
Old Oct 4, 2007 | 07:50 PM
ok thanks alot i did look for a tag but it was already removed i guess
Old Oct 5, 2007 | 12:09 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Did you check the RPO codes under the console lid?
Old Oct 8, 2007 | 06:45 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
are you sure its a 9-bolt?
9-bolt was only available in the 350/auto in '86 as a 3.27 ratio. 305/auto got a 10-bolt 2.73 or 10-bolt 3.23 with G92
Old Oct 8, 2007 | 07:09 PM
yea it is a 9 bolt. and i always thought that they never relesed any 350tpi cars in 86. i thought only like 50 or so were made for test cars
Old Oct 8, 2007 | 07:11 PM
formula_pilot's Avatar
Car: 89 Formula
Engine: LB9
Axle/Gears: 9 bolt / 3:45
Chances are, a gear oil change is long overdue on that 9 bolt. If you go ahead and change the oil, which requires removing the rear cover (easy), you should be able to find the ratio scribed somewhere on the ring gear. Worse case, count the teeth on the ring and pinion and do simple division. Do not be afraid to pull the cover, it is a very easy job.
Old Oct 8, 2007 | 08:08 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
Jack up the rear end with both wheels off the ground (in case you have a posi unit) Use jack stands, block the front tires.
Mark the driveshaft. Have your buddy turn the rear wheels one complete turn. Count how many times the driveshaft went around.
If one turn of the wheel axle gave you 3.5 turns of the driveshaft, you have 3.50 gears.
Old Oct 8, 2007 | 08:59 PM
QuickStyle's Avatar
Car: 91 Z28
also on the front of the gear housing on the bottom it will said "borg warner" if its a 9-bolt
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
