tpi problems help me fix it.
Old Oct 5, 2007 | 11:34 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
ok so the car is an 86 camaro z28 305tpi auto. here is the problem
when i give the car gas it boggs down and wants to shut off.
my thinking is that it isnt getting enough gas... i put a different throttle position sensor on and maf sensor. i had those laying around so i tried them and its still doing the same thing. i havent checked the fuel pressure yet but it has a brand new fuel pump in it. i havent checked the fuel filter yet but it has a huge stumble i think it is more than just that. let me know what you guys think im trying to narrow this down.
Old Oct 5, 2007 | 12:19 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: tpi problems help me fix it.
First make sure your fuel pressure is good, if it checks ok check your injectors. Here is a thread with more info:
https://www.thirdgen.org/forums/tech...ssue-89-a.html
Old Oct 6, 2007 | 10:09 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
what fuel pump did you put on there? do you have a AFPR? the increased pressure from a new fuel pump could of blown a gasket in a AFPR and making your motor run off of whatever psi is comming straight from the pump
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86IROC112
Aug 17, 2015 02:00 PM
jackhammer
Aug 15, 2015 10:04 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
