Fuel Pressure on dead GTA
Old Oct 8, 2007 | 04:38 PM
Cragar87's Avatar
just checked my fuel pressure on my L98 91 GTA. When we first started the pump fuel pressure was at 46psi. Car idled at 38psi, and when I tried to bring it WOT or even 3/4 throttle shot to 46psi and then stalled.
I have adjusted the timing to factory, new spark plugs and wire, new fuel filter. I don't think it's my pump. I was thinking a bad ECM or injectors, any thoughts?
If anyone remembers this was my car that I bought and died on the way home and hasn't run since.
Old Oct 8, 2007 | 07:36 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
Re: Fuel Pressure on dead GTA
i dont think has anything to do with your fuel pressure... it sounds like its exactly where it should be.
Old Oct 8, 2007 | 08:00 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
The more senior forum members would say, "You have to have fuel and spark." Start your troubleshooting there first.
Is the ecm providing any error codes?
If you're getting 46psi at key-on (engine not running), it looks like you have proper fuel pressure. Even though you replaced plugs and wires are you sure you have a good spark? Maybe a bad coil or ignition module?
Old Oct 8, 2007 | 09:06 PM
Cragar87's Avatar
I replaced the coil with the plugs and wires, it was a cheap setup to try and get the car running. Ignition module got tested and it was good. TPS is good still, but old.
Old Oct 8, 2007 | 09:20 PM
Guest
Guest
Posts: n/a
Check your injectors. Do they happen to be Multecs? I just went through this recently... fuel, spark, fire, poor running. 1 bad injector.
Just check the resistance, should be around 16 ohms each.
Old Oct 8, 2007 | 10:14 PM
Cragar87's Avatar
Yeah I should test them. I know the locking clips are in bad shape, and the guy who owned before me put mismatching injectors on it. I was thinking about getting a set of LT1 injectors.
Could this be EGR related?
Old Oct 8, 2007 | 10:17 PM
Engine: 2.3l 4cyl
mismatching injectors deffiently cant be good
Old Oct 9, 2007 | 08:13 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
I would say to ohm the injectors, if they are mismatched more than likely some have already went out and were changed, now the original ones left are starting to fail.
Old Oct 9, 2007 | 12:57 PM
Cragar87's Avatar
I think I will replace all injectors really soon. I saw completely re manufactured LT1 injectors on Ebay cheap, does anyone about buying injectors off ebay? I heard I should go with Ford's or Accel injectors too.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
