anything bad happen if i tightened my roller rockers to tight?
Old Apr 2, 2001 | 02:18 PM
bad camaro RS's Avatar
jus checking i have a 87 350 roller motor how can i tell if theyre to tight?
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old Apr 2, 2001 | 06:51 PM
98_1LE's Avatar
YES bad things can happen, ranging from valve float, excessive cam wear or piston to vlave contact (expensive!). The only way to check them is to readjust them. I know how to do it but I am not sure I know the best way or can explain it well.
Best of luck
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Apr 2, 2001 | 11:51 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I THINK you loosen the roller rockers until you hear a slight tapping. and then tighten it a 1/2 turn I belive.
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
