anyone with firebird and MAF......
Old Apr 3, 2001 | 12:11 PM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
is there an extender that plugs into the MAF connector or are your harnesses just different. On a camaro they dont have enough slack to reach where your MAF would be. Just curious because I was thinking of fabricating a nice cold air induction setup for my car.
355 10:1 , AFR 190 heads, LT4 HOT cam w/ 1.6 roller rockers, complete Superram intake, 58mm BBK TB, 24# injectors, screens out of MAF, MAT relocated, March underdrive pulleys, Streetdampner, Crane HI-6 ignition, 160 thermostat, K&Ns, TES headers(Jet hot coated), Mufflex 4' cat back, B&M shift Kit, 2500 converter, and 3.27s.
Old Apr 3, 2001 | 08:19 PM
Mark 89Formula's Avatar
Different harness on the Firebird. No extension required. SLP has a premade harness for this very purpose when adding their cold air package to a Camaro. It's available seperately and is called a MAF Sensor Wire Extension Harness (PN 21021) with a list price of $14.95. Has the MAF connector on one end, crimp connectors on the other, and is about 12" long or so. A more elegant solution would be to replace the crimps with the correct Weatherpack connector so you don't have to hack up the factory wiring (also easy to return to stock).
Old Apr 3, 2001 | 10:18 PM
Guest
Guest
Posts: n/a
I could be wrong, but I dont think theres a weatherpack connector available for the other side of the maf connector.
Old Apr 3, 2001 | 10:57 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I hear some fabrication coming............
Old Apr 4, 2001 | 08:25 AM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
well if anyone knows of the female connector for this let me know. I am not about to open up a can of worms by cutting into the harness. Thanks
Old Apr 4, 2001 | 09:22 PM
Madmax, upon further introspection I believe you are indeed correct about the unavailability of that connector. Oh well, there's always the soldering iron and shrink wrap.
Mike, I can understand you not wanting to hack up the factory harness but it might be the only option.
64goatman
Sep 9, 2015 01:09 PM
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
