hey i cant pull up check codes, bad prom MAYBE?>
Old Oct 17, 2007 | 12:32 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i tried pulling up check codes on the AB terminals and i wont flash or anything, i did everything right. my mechanic couldnt communicate with the computer either, i already swapped the computer. i have a memcal and a Prom, i ordered a stock prom last Friday it should get here very soon, and ill test it and let you know. becuase the car does run, the SES lights up with the key in the on posistion but stays on and doesnt blink. the light stays light during idle. but doesnt flash, or even faintly dim out or super flash, it just stays lit. i checked everything, its elimination down to the Prom. What do you guys think it can be.
Infested
May 22, 2018 11:56 PM
mizz0313
Aug 12, 2015 06:45 AM
apie2546
Aug 10, 2015 05:43 PM
squiggy2
Aug 9, 2015 09:30 PM
gwade12
Aug 8, 2015 08:17 AM
