what head gasket will work better with edelbrock heads fel-pro 1003 or 1010.
Old Apr 5, 2001 | 01:59 PM
travsirocz's Avatar
Car: Two 1987 Iroc-Z Z28s
Engine: 5.7 TPI ZZ4 1.6 Roller Alum. Head
what head gasket will work better with edelbrock heads fel-pro 1003 or 1010. Why?
1987 Camaro Iroc-Z Z-28 with a TPI 5.7
-Ram Air,K&N Filterchargers, Gutted Mass
Airflow Sensor, Throttle Body Airfoil,
Edelbrock TES Headers and Y pipe, Gutted
Cat, 3 inch exhaust, Flowmaster
-Hypertech Thermomaster Chip, 160 deg Stat,
Adjustable Fuel Pressure Regulator
set at 50 psi, MSD Cap, MSD 8.5mm wires,
Accel Coil, MSD 6AL Ignition Box, Accel
Plugs
-Richmond 3.73 Gears, B&M Transpak,
B&M Rachet Shifter, Energy Suspension
Products
-Fiberglass Cowl Induction Hood,
Purple Neon License Plate Frame,
16X8 Rims with BFG 245 50's,
Pioneer Deck, 2 JL 12's in a Q-Logic
Box with a 300 Watt amp
What you can put between your ears,
no one can take away.
Old Apr 5, 2001 | 11:38 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
First off, edelbrock will only tell you to use the 1003 (steel ring). They will not recommend the 1010 (copper ring).
My concern was that with teh 1003, the steel rings will actually dent the softer aluminum heads ... called brindling or something like that. It is a minor relief, like 0.001 or so. BUT you have to always use the 1003 gaskets in order to follow the same "dent".
I thought about using the 1010 so as to avoid this problem. I could not find anyone who had used the 1010, but I could find lots who used the 1003 and had no problems. Even race shops that pulled the heads off quite often.
In the end, after much deliberation, I choose the 1003. At least if I have a problem with them, edelbrock will warrenty them (I can't imagine what you could return them for).
Perhaps you find others who have used the 1010's. I could not.
Mark.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
86IROC112
Aug 17, 2015 02:00 PM
MY87LT
Aug 17, 2015 08:43 AM
89-S-dime
Aug 12, 2015 11:57 AM
