difference between TBI and TPI replacement engines?
Old Apr 5, 2001 | 11:40 PM
james_fearn's Avatar
What is the difference between a TBI and TPI engine? Are the heads designed specifically for the injection setup? It is probably a moot point for my purposes anyway.
I want to get this long block at the bottom of the page:
http://www.paceparts.com/specials_page.htm
It is the caprice TBI engine at paceparts. Then I'll install 23* TFS heads and a ZZ4 cam. I want to switch to a one-pice rear main seal and centerbolt valve covers. I think it is the most inexpensive and best part selection than any alternative that I can think of or have looked at that is all new. I'd get a ZZ4 but I want my EGR to function w/ out messing to much w/ it. Considereing it has a decent bottom end, a roller setup plus the pans/covers, and a balancer it is cheaper to get the long block then to buy them seperatly because I currently have a two-piece, non-roller, traditional VC 305 TPI.
Any thoughts? Any problems with the above??
James
1985 Z-28 305 TPI
221,000+ mi., Original Eng.
Old Apr 5, 2001 | 11:53 PM
83Z28406's Avatar
Car: 83 Z28
Engine: 400
Transmission: Th 350
Axle/Gears: 3.27 9 bolt
the biggest difference is the heads tpi is polished from the factory tbi is rough casting the cr is a little higher on tpi also
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92purpz28
Aug 11, 2015 02:30 PM
