? for anyone useing the GMPP Chrome Center Bolt Valve Covers
Old Apr 8, 2001 | 07:44 PM
Jas89TTA's Avatar
I installed the Gm Performance Parts Chrome center bolt valve covers the ones with the red bow tie on my 350 TPI. On the right hand valve cover the 90 degree elbow for the PCV system will not fit these covers the hole is larger than the stock hole. The elbow connect's to the pcv pipe that goes to the TB (I think) the intake is all apart and I'm not sure where it goes just yet What did ya'll do to make it work or Can I just install a breather cap and block off the other end. Thanks
Old Apr 9, 2001 | 08:49 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I'm not sure what isn't fitting. On mine, the PCV fit fine.
On the other side, I didn't have the piece going to the valve cover from the rubberjoint, so I took an old PCV valve, gutted it, and stuck it in. Works good for me.
Bob '89 Ram Air Formula 350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Old Apr 9, 2001 | 08:51 AM
travsirocz's Avatar
Car: Two 1987 Iroc-Z Z28s
Engine: 5.7 TPI ZZ4 1.6 Roller Alum. Head
Where is the cheapest place to pic these valvecovers up?
1987 Camaro Iroc-Z Z-28 with a TPI 5.7
-Ram Air,K&N Filterchargers, Gutted Mass
Airflow Sensor, Throttle Body Airfoil,
Edelbrock TES Headers and Y pipe, Gutted
Cat, 3 inch exhaust, Flowmaster
-Hypertech Thermomaster Chip, 160 deg Stat,
Adjustable Fuel Pressure Regulator
set at 50 psi, MSD Cap, MSD 8.5mm wires,
Accel Coil, MSD 6AL Ignition Box, Accel
Plugs
-Richmond 3.73 Gears, B&M Transpak,
B&M Rachet Shifter, Energy Suspension
Products
-Fiberglass Cowl Induction Hood,
Purple Neon License Plate Frame,
16X8 Rims with BFG 245 50's,
Pioneer Deck, 2 JL 12's in a Q-Logic
Box with a 300 Watt amp
What you can put between your ears,
no one can take away.
Old Apr 9, 2001 | 12:59 PM
Jas89TTA's Avatar
RCR, It's the 90 degree Elbow grommet on the RH side valve cover that don't fit. I called GM today and they said they know the hole is larger than stock but don't have a service part for it so I'll see what I can find at Discount Auto Parts and I'll have to rig something up.
travsirocz, The covers run about $100.00 for the pair
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 01:18 AM
