ZZ4 cam with no EGR??
Old Apr 5, 2001 | 04:42 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Anyone running the ZZ4 cam with no EGR valve?
Just wondering if I'm asking for any problems by not running the EGR with this cam. I guess I'm a little hestitant to remove since I had such bad detonation problems early on with the TPI.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, 12.40 @ 108 w/1.79 60'
95 Trans Am Conv.- LT1
Old Apr 5, 2001 | 10:12 PM
98_1LE's Avatar
I am teetering back and forth with eliminating it with tuning or plumbing it from the #8 header tube like Kevin did when I install the ZZ4 heads/cam on my '87.
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Apr 5, 2001 | 11:25 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I am running the ZZ3 cam with Edelbrock RPM heads (#6089). They do not have the exhaust crossover passage. So I unhooked my EGR and it is just there as a blockoff.
For my setup, it runs fine. No detonation. Stock 1987 PROM too!
I don't live in a HOT climate, so that helps my situation out. As well the aluminum heads are a bit better than cast for detonation.
Perhaps something else is causing your detonation problems.
Mark.
Old Apr 6, 2001 | 11:50 AM
2QUIK6's Avatar
I believe the main source of the detonation was the TBI cam that was left in after the conversion to TPI. The TBI cam has a very small lobe separation of 104. I believe TPI's like at least 112.
It's not detonating now after the EGR and chip timing tables were greatly altered, and now too much timing is removed because I have false knock now from rod bearings knocking, hence the reason for the rebuild now.
What I'd like is to take care of the toiming in the chip after the rebuild and get rid of the EGR, just putting tons of carbon deposits in the intake! And hopefully the TPI matched cam will help also.
Old Apr 9, 2001 | 03:09 PM
CanadianBeast's Avatar
Hey Mark, where in Alberta is Sherwood Park?
lt500r55
Sep 1, 2021 01:30 PM
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
