What cam to get?
Old Apr 9, 2001 | 04:34 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
What cam to get?
Summit racing has a cam kit for pre87 tpi cars. 204/214 duration@.050lift,.420"/.442" lift. They claim 40 horses w/ superchip installed. Will this be a good cam for my 85tpi Trans am? Or is there a better one? I plan to install the cam and put on some edelbrock headers so I should see a little more than 40 horses. Any other suggestions would help also.
85 305tpi Trans am
flowmaster exaust
K&N air filter, 4:11 rear gears
Old Apr 9, 2001 | 07:36 PM
IROCZ88's Avatar
With 4.11 gears you may want to get a cam designed for a higher rpm range. Then you'll have to compensate with the intake, heads, etc.
'88 IROC TPI 355, '69 truck 4-bolt, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp 1.6 Roller Rockers, Comp Cams CS 252AH-12, ported '86 TPI converted to speed density, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
If you have any questions on converting from TBI to TPI email me at jdkchevy70@yahoo.com
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
Old Apr 9, 2001 | 08:30 PM
Dan87IROC-Z's Avatar
If I was to use that cam in a 305 TPI car, I would want to use 1.6 roller rockers for sure. That will bring the lift up to .448"/.471" and will help you out more, especilly up high. With that lift, I would strongly recomend that you change out your springs and retainers, and while you are in there, your valve seals too. I know stock springs are supposed to be good up to .500" lift, but while you are swapping a cam, you might as well spend the money to get the entire valvetrain in good shape. You can also have a machine shop or auto parts store clean up your heads and valves for you, I am sure there is a good deal of carbon deposits on them.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Apr 9, 2001 | 08:47 PM
rdog30's Avatar
Car: 85&95 Trans am
The cam kit comes w/lifters,springs,& retainers. If I change the rear gears what should I install?
85 305tpi Trans am
flowmaster exaust
Old Apr 9, 2001 | 08:51 PM
FlashGTA
Guest
Posts: n/a
The cam is a dog, had one in my 84, same numbers made by speedpro, you won't be happy!
Old Apr 9, 2001 | 09:03 PM
JJ's Avatar
JJ
forgive me for this, but this is what always happens to me - "look in the tech section, there is/are articles on cam selection, ect."
once again, sorry but I couldn't resist
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
