Poor throttle response, backfiring...
Old Apr 10, 2001 | 01:57 PM
Cannon's Avatar
I recently took my '89 out for a drive, only the second or third time this year. The last time I was out cruising I noticed something.
When I mash the peddle the engine hesitates and then picks up slowly, at this point I get some minor backfiring as well.
I just cleaned my K&N's so it's not dirty filters... Could this be bad injectors?... I have no idea.
Please help... I doubt I could take me parents Caravan at the moment.
Old Apr 11, 2001 | 07:58 PM
Cannon's Avatar
Anyone?...
Could use some ideas before taking her to the shop.
Old Apr 11, 2001 | 08:32 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Incorect timing is my guess.
Old Apr 11, 2001 | 11:13 PM
Stang Eater's Avatar
mine did that until i found out that i had a spark plug wire that was burnt through and grouded on the header tube, but it only popped( backfired) weh i let off the gas if it was revved up a bit
Old Apr 12, 2001 | 12:10 AM
STOCKROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Cannon:
</font>
Backfires out the exuast of intake. Does it backfire at full throttle are just part. More details please.
1989 Irocz
350 T-5
Old Apr 12, 2001 | 12:24 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Maybe try putting in a fresh tank of gas or fuel system cleaner. If you've driven only 2 or 3 times this year, do you still have last years gas? If so, you may have some lacquering in the lines or tank that has reduced pressure of partially clogged the injectors. Backfiring under the hood (throttle body) usually means low fuel pressure. Tailpipe backfiring is usually related to timing. Which do you have?
1972 Corvette LT1
Keith Black 9.7:1 Pistons
Comp Cams 480/480 lift @220 Duration
Original 4 Bolt Steel Crank
1.5 Roller Tip Rockers
336 Posi Rear Chunk
1991 Speed Density TPI setup
DUI Special order Tachdrive Distributor
[This message has been edited by 72LT1VETTE (edited April 11, 2001).]
Old Apr 12, 2001 | 01:25 AM
86TransAmTPI's Avatar
I had the same problem before.My problem was because I had bad plug wires(they were really crispy from hanging on the exhaust manifold) and 2 of my plugs wires were switched with eachother.So my firing order was basically messed up.Just my personal experience.
Check out My Trans Am:
http://hometown.aol.com/italianknight178/index.html
Old Apr 12, 2001 | 04:14 PM
Cannon's Avatar
Okay, I checked my wires and one was popped off a little on the distributor. So I took pushed it back in.
I took her out and she feels waaaay better.
I'm going to replace the rotor, plugs and wires then get my timing checked.
Thanks a lot guys.
Old Apr 13, 2001 | 04:04 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
definatly a sparkplug wire melted or burnt
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
BWilcox
Sep 20, 2015 12:19 PM
Randomtask2
Sep 7, 2015 05:06 PM
rsrookie
Sep 5, 2015 07:08 PM
