Pinging, timing, thermostat question...please help?
Car: 13' ZL1/91' Z28/10' Audi A5
Engine: 6.2L SC/5.7L 350/2.0L Turbo Quattro
Transmission: M6/700R4
i recently threw in a 160 degree thermostat and i noticed that the car doesnt run right. and its pinging. i read in another topic that if the thermostat is changed then i would have to change the chip. so i ordered a JET stage 2 chip that is made to go with the 160 stat. hasnt arrived yet.
my question is, do i have to mess with the timing after i put the chip in? and if so settings do you guys suggest? or does the chip correct the problem? thanks in advance
SS 17x9.5 wheels,
HOTCHKIS 1"drop springs,
HOTCHKIS tower brace,
Bilstein struts and shocks,
K&N filters,
MSD 6A,
MSD 8.5mm Wires,
MSD Cap & Rotor,
Hypertech airfoil,
SLP intake runner (plennum not ported yet, soon)
High flow cats,
SPOHN panhard bar, lower control arms, and subframe connectors,
Baer front track system,
3" Flowmaster Exhaust System,
2100 Stall High Performance Torque Converter,
300 watt sound system,
and soon to come...ZZ4 crate motor...hopefully.
[This message has been edited by HybridZ (edited April 14, 2001).]
SS 17x9.5 wheels,
K&N filters,
MSD 6A,
MSD 8.5mm Wires,
MSD Cap & Rotor,
Hypertech airfoil,
High flow cats,
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
You should've just put a 180 thermostat in there first instead of wasting your money on the crap chip!! Personally, I have a 160 thermostat in my car with an adjustable fan switch hooked up and my car never pings even with 90 octane gas! If you tune everything properly you can run a 160 w/out performance problems!!
