Longtube Header Install
Car: '89 Formula
Axle/Gears: G92
This weekend I'm going to install my longtubes and I was just wondering if there were any tips or tricks to making the job easier, Thanks.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Longtube Header Install
What type and size headers?
I was able to get mine in with the engine mounted. DS from the bottom and the PS from the top.
Mine are headman 68460 longtubes 1 5/8 primaries.
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
I would suggest jacking up the motor. You might be able to get them in w/o jacking the motor, but if you take 10min. to unbolt the motor they will just slide in. I just did the hedman longtubes a couple weeks ago. I did the drivers side from underneith. The passenger I had to remove the starter and slid it in from the top.
Dialed_In
Aug 20, 2015 01:45 PM
