Performance of stock 1970 350 with tpi from 305
Car: Jeeps
Engine: 1970 4 bolt 350, 19000 miles & TPI
Transmission: Tubo 350
Axle/Gears: 4:11
Hello,
Is it possible to run a swapped 305 tpi onto a 350 without changing the injectors to 22 or 24 pound versions?
Thanks,
Jim
Thanks,
Jim
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Performance of stock 1970 350 with tpi from 305
Yes, depending on what year the 305 TPI is from. Remember they changed the intake bolt pattern in 1987, and the 1970 heads will have the older pattern. You can either get an aftermarket intake manifold from Edelbrock, or use a grinder on the middle four bolt holes to change their angle.
The 19lbs injectors are good to about 350 hp at the flywheel at 5000 rpms before they cant keep up and you go lean.
Car: Jeeps
Axle/Gears: 4:11
Thanks very much for the info.
I've read that the center 4 bolts in the manifold require washers... As I've never actually seen the difference between the two heads it is hard to figure out. It is possible to install the TPI on a set of old heads though, right?
Thanks again Kevin for the information. I'm putting my 350 TPI into a Jeep YJ, so higher rpm won't be a regular occurance!
Jim
Jim
Car: 88 GTA "Cocaine"
Engine: 350 tpi
from 89-92 gm used the same fuel injectors in 305 and 350's they just changed the fuel preasure regulators
by an ajustable fpr and crank it up intill you get black smoke out the pipes and back it off untill the exsaust gets cold and run the hell out of it.
Car: Jeeps
Axle/Gears: 4:11
Thanks, jamon8. Looks like it should be a go!
Jim
Jim
Car: Jeeps
Axle/Gears: 4:11
Wow 123pugsy. You're awesome. Thanks a lot. Jim
I've had both in my hands, and the part number stamped on them is different. Not to mention Rich at Cruzin Performance has done flow tests and proven they are different.
Car: Jeeps
Axle/Gears: 4:11
Hi Kevin,
Thanks for the info. I have just purchased what seems to be a rather complete '92 sb tpi from a 350.
Jim
Jim
NBrehm
Aug 25, 2015 11:49 PM
