89 GTA WONT START???
Old Oct 27, 2007 | 04:52 PM
PC89GTA's Avatar
Ok, It seems the only way i can start my GTA 350TPI is with a shot of
starting fluid. Idles but seems to be doggy. If i shut the car off it wont start again unless i shoot some starting fluid in the TB. Anyone have any suggestions on a solustion?
oh yeah, I do here the fuel pump turn on
thanks
paul
Old Oct 27, 2007 | 05:38 PM
jed5161's Avatar
Car: 88 Trans Am GTA
Engine: 383 Lingenfelter/AFR 670 hp
Transmission: 700r4 3500 stall
Axle/Gears: 3.90 9 inch
Re: 89 GTA WONT START???
do a pressure test. it maybe just weak enough that it wont start but idle if assisted. Also check fuel filter.
Old Oct 27, 2007 | 07:39 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
ditto.
Old Oct 27, 2007 | 07:43 PM
19redbird89's Avatar
Car: 1989 Pontiac Trans Am GTA
Axle/Gears: 3.23 9 bolt
Been there hthat happen, it is probably the fuel pump but I would start with the pump being that it is cheaper. Good luck
Old Oct 27, 2007 | 07:56 PM
MADMAXGTA's Avatar
Car: 89 TTA
How many miles are on it? has it been sitting for a while or is it your daily?,mines @ 72,000 and I just started having similar problems
Old Oct 27, 2007 | 08:30 PM
PC89GTA's Avatar
thanks guys.... I will change the fuel filter first, then move onto the pump if it dosnt fix the problem. I'll keep u posted on the results....
it already has a new cap, rotor, plugs, wires, injector harness and injectors
paul
Old Oct 28, 2007 | 07:42 AM
PC89GTA's Avatar
oh yeah, can someone tell me what the factory ID # is on the PROM?
Old Oct 30, 2007 | 02:59 PM
wolfspirit187's Avatar
Car: 1988 trans am GTA
Engine: 350 V8 tpi roller motor
Transmission: 700-R4
Axle/Gears: 3.73 b/w posi will change out soon
on that car check the ign switch not the key lock but the switch it self my car was doing that and i changed it and boom worked like normal that switch slides to make contact to the pump and the rest of the system it can contact the rest and not the pump fully so u will get a low pressure ( like in the fail safe mode ) check that and also the wires to it
Old Oct 30, 2007 | 04:20 PM
PC89GTA's Avatar
where is the switch located?
i will check out before i install a new pump. thanks
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Winchester1094
Aug 18, 2015 10:23 AM
Street Lethal
Aug 14, 2015 08:25 PM
