rough idle???
Old Apr 15, 2001 | 11:50 AM
Bad Blk Z's Avatar
rough idle???
When my car heats up, and I sit at a light in drive the car will idle fine thin it feels like it looses 1 or 2 cylinders real quick. its not like miss mor like it dies and comes back up real fast. Plus at crusing speeds when i just barely touch the gas it will do the same thing. Its got a newer tps (6 months old) and a new tune up. I replaced the O2 the same time as the tps but i have run some 110 octane leaded race gas to stop the ping at the track. Any input would be greatly appriciated.
91 Z-28 Coupe
L-98, 700-r4
Borla cat back
Performance Resource chip
Centerline wheels
K&N, Gutted air boxes
Gutted cats
Best Pass = 13.710 @100
Best 60' = 1.842
on M/T Sportsman Pros
"I bought my car to get me girls, I'm still waiting"
Old Apr 16, 2001 | 01:06 PM
MikeC.86Roc's Avatar
Its not giving you any codes is it? How many miles does this motor have on it? If you have not yet, try flashing the codes to see if you have one set. The oxygen sensor will not throw a code if it is bad, only if it senses a lean or rich condition. I have also heard that leaded race gas can ruin an oxygen sensor too. Did you replace the cap and rotor in your tune up? Keep us posted...
Mike C
88 Iroc 5spd
355 TPI, AFR 190s and lotsa other mods
86 Iroc in pieces!
Old Apr 16, 2001 | 02:04 PM
87IROC350's Avatar
Engine: 5.7
Leaded gasoline will ruin your O2 sensor.
87 Iroc 5.7, AFR190, SLP Cam(218/224), SLP 1 5/8 headers & cat back, Random CAT, SLP Runners (matched intake-runners-plenum), 48mm TB, 6E(arap) chip, Vigilante & Probuilt trans.
Old Apr 16, 2001 | 07:08 PM
Hey 87 Iroc, what kind of times are you running? I have a very similar setup and only getting 13.4's.
Old Apr 16, 2001 | 09:06 PM
Bad Blk Z's Avatar
No I did not replace the cap and rotor. The check engine light isnt on so i dont think there is any codes but im not sure how all that works im more of a carb guy playing with tpi. I need some quck help the car used to be reall consistant now its not and points season starts saturday so i need some help. Thanks
91 Z-28 Coupe
L-98, 700-r4
Borla cat back
Centerline wheels
Gutted cats
Best 60' = 1.842
Old Apr 16, 2001 | 09:58 PM
MouseCamaro305's Avatar
have you replaced the O2 sensor since your ran leaded fuel? and keep in mind, any sensor that fuel or exhaust touched while you were running leaded fuel has probably "hazed" over........
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
