Differences between years of TPI
Old Apr 17, 2001 | 01:06 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
What are they?
I know that they changed the setup a little in the years from 86-92...
What did they do??
And what are the differences between the 305 TPI and the 350?
Thanks!
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old Apr 17, 2001 | 08:01 PM
Vader's Avatar
Kiz,
There is a pretty good description of the changes in the Tech Articles.
Off the top of my head, the early '85 TPI used a digital MAF and the slower 8-bit processor with MAF adapter module.
'85-'88 TPI used the cold start injector and control mounted at the front of the intake manifold.
'85-'86 used the older style coil-in-cap distributor, whereas the later styles used the separate coil.
'85-'87 used a single electric cooling fan.
'85 - early '87 used the "garbage can" air cleaner housing for the Pontiacs.
1987 and later TPIs (and most other GM V-8s) used a roller lifter and roller cam.
'90-'92 TPI used the speed density control scheme instead of the MAF used from '85-'89.
I'm sure there are other differences, but those are a few.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Vintageracer
Jan 10, 2020 05:33 PM
Wade787b
Sep 29, 2015 01:15 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
