tbi-tpi fuel lines
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
tbi-tpi fuel lines
im at work right now so i can search to much on here. pita govt computers, anyways, im doing a swap to tpi from tbi. which fuel lines do i need to change out? i know the fuel lines running from the tank to the engine should be good for the tpi. but which do i need to hook up to the tpi?
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: tbi-tpi fuel lines
I have drove mine about 5 miles..and idled for about 30min ontop of that with TBI rubber, but TPI pump n pressure. No issues so far.
I looked up the hoses, and TBI and TPI call for the same part number in the aftermarket world. Who knows if they were different for GM
Car: 1988 firebird
Engine: 305 tpi
so its the same fuel lines from the fuel rails back? i figure they would be different.
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
The GM lines for TBI and TPI are the same for the return line and the line from the tank to the chassis hard lines. The feed lines are different part numbers. The aftermarket is most likely selling a line already able to handle the higher pressure of TPI and just listing it for TBI as well.
Car: 1988 firebird
Engine: 305 tpi
which aftermarket company has the feed lines for the tpi?
Car: 90 Formula
Pure Choice offers a braided stainless steel kit to replace the lines from the chassis hardlines right up to the intake. They can also make them to whatever length you wish. I don't know of anyone making a rubber line. I may have a spare feed line from when I did my TPI swap back in Nov. '06. I'll let you know if you're interested.
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I run a TPI fuel pump with my TBI engine and all my TBI softlines have held up fine. Been like this for about 40,000 miles now.
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
You need to change out the hard lines that go from the TPI fuel rail to the ruber lines, which ones you need depend on weather you have a serpintine belt or v belt system
Car: 1988 firebird
Engine: 305 tpi
i need the feed lines for a serpentine belt system.
mongoose- i am interested in those feed lines if you still have them
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
all the lines are the same except for those hard lines that go behind the serp set up. You can get them at tpiparts.net.
Car: 1985 Camaro Iroc-Z
Engine: 5.0 TPI
Axle/Gears: 2.73 posi
I've read that some have used AN fittings/adapters to connect to TPI. Restating a post, TPI requires more PSI than TBI. About 45 vs 15 PSI.
Good luck on the project, you are a true "hot rodder"!!!
Car: 1988 firebird
Engine: 305 tpi
thanks, im hopin to have the project complete while im home on xmas leave. im still collecting all the lil parts. my buddy is gonna let me use his lift to remove the fuel tank to replace the fuel pump. the only thing im dreading is the wireing hareness. i hate wires.
Are you changing the complete harness or converting the tbi harness to tpi?
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
On some of my street rod TPI installations, I've gone to junk yard and gotten the braided lines from TBI pickups in the 89-92 range. They are about 40-45 " long and fit the TPI fuel rails.
I run them down the side of serpintine and under engine to frame rails and then cut and splice on the saganaw fitting for return and use a fuel filter to connect the supply line.
Looks pretty good, and cheap.
Car: 1988 firebird
Engine: 305 tpi
thanks for the suggestion scuzz. im kinda nervous about this swap but yet i cant wait to do it and get it running. ive already did a big swap to my car before. changed it to a manual tranny. that was a pita because i didnt have all the correct parts i needed. to answer your question battman, im gonna take the tbi harness out and put the tpi in. im not educated on repinning. shoot im not educated on tunning either. but hopefully i will soon.
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
