TPI trouble codes
Old Oct 30, 2007 | 10:41 PM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
TPI trouble codes
I get a 36 on the computer. Is there a code translation list?
Found the definition Just had to search.
Last edited by 86 Cali IROC; Oct 30, 2007 at 11:08 PM. Reason: found the code definition
Old Oct 31, 2007 | 07:23 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: TPI trouble codes
http://gmtips.com/3rd-degree/dox/tip...es/code-01.htm
Old Oct 31, 2007 | 10:11 AM
Axle/Gears: 373s
Thanks for that tip. Just recently, the engine on idle began to surge up and down. However that is the only code in the ecm (36). Any thoughts? It was running great last week. Took it to a get a smog check and they had told me it was running too rich. I replaced plugs, oil, and O2 sensor. I also ran an additive cleaner in the tank for the engine. I think when I accelerate the engine runs great, but bringing it back to an idle it surges. I don't know. Is the burnoff of the MAF that critical to smog? Cali's laws are tough.
Old Nov 2, 2007 | 07:21 AM
I would check the fuel filter. If that isn't the problem, check the Idle Air Control Sensor (located on the passenger side of the throttle body). On my car, the spring was compressed with carbon and caused the engine to surge on idle.
If both are ok, I would check for vacuum leaks.
Sorry, not sure about the MAF.
Hope this helps!
Old Nov 2, 2007 | 07:39 AM
Blue-Z28's Avatar
Car: 86 IROC-Z
Engine: 305 tpi
Replace both MAF Relays. My IROC did the same. Replaced relays>FIXED!
Got them at a GM dealer.
evilstuie
Apr 14, 2016 08:52 PM
GouldyGTR
Aug 21, 2015 10:43 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
