Comp Cams choice
Old Apr 17, 2001 | 01:14 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Comp Cams choice
Was wondering if anyone here used the Comp Cam with 210/220 duration with .500/.510 lift and 114LSA? And what type of results did u get with it.....curiosity killed the cat here was thinking of experimenting eith it in my car seems to be would idle very nice and with the lower duration and high lift would seem to ramp up very quickly
gimme your thoughts
later
sorry i dont have the part# cant find my catalog
LOOKING FOR FELLOW F-BODY ENTHUSIASTS TO START THIRDGEN CLUB IN NW IN AND FAR SOUTH CHICAGO SUBURBS , DROP ME A LINE IF INTERESTED OR POST ON THE MIDWEST BOARD
1989 Turbo Trans AM
100k and counting it breaks as fast as i wrench:-)
1991 Formula 350
daily beater with 45k
SLP catback
flowbooster
runners on order
MSD6
cold air kit
soon to be vortec headed,vortec intake, headers and cam etc
ASE Technician
Jaguar Certified Technician
Chat Mod @ thirdgen.org
"If it aint broke make it faster"
Old Apr 17, 2001 | 08:08 PM
Vader's Avatar
I've got the 220°/230°, 0.510"/0.510", 114° LSA Comp in an LT1 and the idle is very acceptable. There is only the slightest burble and lope, probably mostly from the lift and advanced valve timing more than from overlap. It is very smooth all the way down to about 800RPM in DRIVE, where the idle begins to lope. It will still idle way down to 450 RPM in gear without stalling, but that's probably due to the SFI, and the PCM stall-saver programming.
Oh, yeah - torque picks up very well at 2,500 RPM and keeps me well planted in the seat all the way to 5,500 or so, where is starts to fall off a bit. That's a pretty good time to shift anyway.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 18, 2001 | 05:50 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Vader,
Are you running that cam in a 305? I was going to go with the one that 3.8transam mentioned, how good would that be in a LB9 305? I currently have the peanut and want to feel the difference.
Rob
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Old Apr 18, 2001 | 06:24 AM
Nitro Don's Avatar
I ran Comp Cams 210/220 .500/.510 1143lsa cam
With the i.6 rockers,lift was .533/.544
I had weak springs on my WP torquer heads,and broke them all off on the exhaust valves,so I never got to push the motor to its fullness.
Track results even with bad springs were:
stock cam 12.4 at 109mph
Comp Cam 12.8 at 116mph
As you can see,mph picked up by 7 mph,and I was floating the valves for most of the run.
Im currenty installing Comp Cams 230/244 with the 1.6 rockers lift will be .544/.576
with 112 lsa
I have to have the heads machined to use this cam,its going to be a radical 305.
Also, the idle was pretty good,you could tell the car was cammed,but it wasnt rough at all.
Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
TCI shift kit
Vette servo
B&M 3-4 upshift kit
TCI Trans Rebuild
2800 stall 9.5" TC
Nitto Drag radials
FUTURE MODS:
BEST RUN:
12.48 @ 109.23 MPH
(with stock heads,cam,intake,and crappy Pep Boy's tires)
[This message has been edited by Nitro Don (edited April 18, 2001).]
Old Apr 18, 2001 | 08:04 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I have that cam .510 lift 220/230 duration in my 350 with forged pistions, and holley heads soon. so I will let you know the results as soon as I get it in my car.
89 Iroc 350 TPI,
Forged pistions
Comp Cam .510 lift 230dur
Flowmaster exhaust
Aluminum Heads SOON!!!
MINI RAM SOON!!!!!
stock TPI for now 24# inj
Old Apr 20, 2001 | 03:47 AM
sonnyb's Avatar
3.8 Trans-Am, the part# to that comp cam is 08-304-8. I have the same cam insatlled in my 1991 z28 tpi right now. Never got the chance to drive or test the car. It does have a kick a##$ sound. Does anyone know if this cam needs a modifed computer chip or other modifications done to the engine? For instance, heads,intake, runners and etc.
Old Apr 20, 2001 | 06:16 AM
Nitro Don's Avatar
I ran that cam with the stock chip in a speed density car.I didnt have any computer problems.I did break all tops of the valve springs on the exhuast side though.I was using 1.6 rockers,so lift was .533/.544
I would recomend double 1.440 springs.
If you dont want to have the heads machined,
you can try K-Motion H-11 1.265 springs which have 130lbs. at 1.7 installed hieght.
Nitro Don
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Jorlain
Oct 8, 2015 01:57 AM
ericjon262
Sep 11, 2015 06:07 PM
scottmoyer
Sep 7, 2015 07:06 PM
masonta
Sep 1, 2015 06:40 PM
