hey mike89z, question about crane hi6
Old Apr 21, 2001 | 01:19 PM
87iroczmd's Avatar
i have a crane hi-6s which is supposed to plug right in to the coil on the tpi's, i have an 87 350 tpi, i hook up the ignition and the car doesn't run right, someone told me you had to advance the timing with the crane ignition for it to work, is this true
Old Apr 21, 2001 | 07:56 PM
mike89z's Avatar
Car: 89 Iroc-Z
Engine: 355
well the directions say to set the timing again after the install so you should probably try that first. Stock should be 6BTDC with the est wire disconected(single green wire between the passenger strut tower and firewall, just disconnect and start the car,then set timing to 6BTDC). See if that helps.
355 10:1 , AFR 190 heads, LT4 HOT cam w/ 1.6 roller rockers, complete Superram intake, 58mm BBK TB, 24# injectors, screens out of MAF, MAT relocated, March underdrive pulleys, Streetdampner, Crane HI-6 ignition, 160 thermostat, K&Ns, TES headers(Jet hot coated), Mufflex 4' cat back, B&M shift Kit, 2500 converter, and 3.27s. Chip is custom(doing it myself) Just got a 2 1/2 Harwood and soon to be painted.
Old Apr 22, 2001 | 02:32 PM
precision350's Avatar
There is one thing that is kind of tricky about the Crane Ignitions. There is a wire (I believe it is brown) that is to be connected to a timing retard module(for superchargers, turbochargers etc.). If you didn't buy the module then the wire needs to be either grounded or connected to a 12v source. Carfully read through the entire instruction manual and you will find what I am talking about.
MustangBeater20
Oct 29, 2022 09:20 PM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
1992Vortec
Aug 31, 2015 08:05 PM
squiggy2
Aug 9, 2015 09:30 PM
