ingnition module keeps goin out!! ned help fast!
i got a 89 iroc sittin in my yard that im workin on n i bought a ignition module 2 times already! what can the problem be? motor is a 305 tpi. n e help?
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Next time it goes out, try just unplugging the two connectors from the back of it for a few minutes first. I bet you'll find that it will work again once you plug them back in. I'm having a similar problem with my GTA, but I still haven't found the root source of the problem yet though.
At least if my little trick works it'll save you some cash.
Black 88 GTA L98
261 RWHP, 345 RWTQ
13.406 @ 103.72 MPH
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back, Stock PROM
E.T.F.A Member #11
Black 88 GTA L98
261 RWHP, 345 RWTQ
13.406 @ 103.72 MPH
E.T.F.A Member #11
I went threw 2 napa crapa in 5 months so i just went with an accel module. no problems I would never buy a sensor or anything from napa pep boyz they sell cheap versions of what the factory put in our cars.
You may have a bad pickup coil in the distributor that is causing the modules to go south. The coil is below the reluctor ring.
Hank
87'IROC Z28
Hanks 87 IROC
Hank
87'IROC Z28
Hanks 87 IROC
