Won't start/Hard start, Pinging...
Old Apr 18, 2001 | 12:48 PM
Baddogw's Avatar
87 IROC TPI on a 90 350HO motor.
Won't start unless initial timing is set above 12 degrees. Then the pinging starts when driving. Whats up?
Have set IAC, TPS, checked for vacume leaks, etc...
Old Apr 18, 2001 | 07:04 PM
Vader's Avatar
Dog,
How is the compression? Low compression can cause poor starting and protracted cranking. Advanced timing can offset the problem to some extent, but doesn't really fix it.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 19, 2001 | 10:22 PM
bowtiez's Avatar
This might not help but, i had tune done at local garage. No one knew the harmonic balancer had spun. Timing was set, but marks were off. Replaced the balancer and starting problem was solved.
Bill
Old Apr 24, 2001 | 12:02 PM
Baddogw's Avatar
Vader
It has been a while, but last time I checked the compression reading was 210-220 on all 8 cyclinders.
As to the spun harmonic balancer, how can it spin when it is "keyed" in place? And that would only give you a incorrect timing reading. Not hard starting or pinging.
Any thing else to check?
Thanks, BDW
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
