383 build advice needed
Old Nov 5, 2007 | 03:43 PM
63moredoor's Avatar
Hi all, I don't usually post here, just lurk around and try to research for my project but I am to the point where I need some pointers. I am building a 383 TPI setup. I plan to use ported stock TPI comonents for now but may upgrade to some better runners etc in the future. Definately want to stay with a long tube runner style. I am using a Powerhouse 383 kit with cast crank. My 350 core is a 89 TBI rollercam from a caprice cop car. I am looking to have an engine with strong low and midrange torque with no real reason to top 5500rpm. I am also planning to upgrade to the 0411 OBDII system. This will be running with a manual 4 speed trans. I need some advice on what to do for a roller cam and heads to be compatible with my goals. I have looked at the vortec, powerhouse, patriot, and even summit and jegs heads just not sure what to choose. I would like the heads to come in at or below $1K preferably below. I haven't really put too much thought into using my current heads but I guess that is a possibility too (don't even know what the are currently) I am also lost as to a cam. All the magazine write up I see are for carbed applications but I want one that will be TPI friendly. So please point me in the right direction here.
Old Nov 5, 2007 | 09:32 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: 383 build advice needed
For a camshaft i would go with a ZZ409. Gives lots of grunt down low. For the heads with a 383 i had edelbrock heads with an intake 2.02 and exhaust 1.6 The intake was to small. I upgraded to dart 200 heads with a 2.05 intake and made a huge difference. Thats what i have and works perfect
Old Nov 6, 2007 | 02:07 PM
63moredoor's Avatar
Thanks, any other input?
Old Nov 11, 2007 | 12:38 PM
63moredoor's Avatar
Any idea what this same combo would produce hp/tq with a LT1, LT4, or LT4 camshaft?
Old Nov 15, 2007 | 11:00 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
440 horse
Old Nov 17, 2007 | 06:46 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I went with the powerhouse 383 stroker kit. Wound up not being able to use the rods cause of clearance issues. Went with eagle h-beam rods which wouldn't work with the pistons, so had to get new pistons. Only thing I used from the kit was the crank and a few gaskets.
If you haven't already purchased the powerhouse kit, might wanna consider the eagle kit.
I went with the Lingenfelter 74211 cam. It's designed especially for TPI.
It works well but the stock heads will need to be modified for the increased lift.
Factory 350 TPI heads aren't bad heads for what you're wanting to do. I had mine modified with 2.02 and 1.6 valves installed, guide plates and springs for $400.
Old Nov 17, 2007 | 08:25 PM
63moredoor's Avatar
After looking at the price difference, I'll probably go with an Eagle balanced rotating assembly. Especially since they offer an internally ballanced version.
Old Nov 18, 2007 | 06:38 AM
MrBill85T/A's Avatar
Car: 85 T/A
Transmission: 700R
I have a eagle stroker crank internally balance, be sure that your machine shop polishes the thrust bearing area . I wiped out a thrust bearing in a hour because of that. Some cranks are not being polished correctly. Other than that it is a good piece
IROCZ1989
Jan 24, 2016 03:55 PM
Reborn756
Sep 4, 2015 03:42 AM
jharrison5
Aug 19, 2015 05:53 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
