ported tpi or mini ram??
Old Apr 24, 2001 | 08:56 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
ok well here is my delema. i am getting a ne engine for my IROC. i have desided to use AFR heads. but im not sure on the intake and up part. i like the mini-ram set up *and additional power* but the mechanic i have now *who is really really good and only works on 82-01 camaros, firebirds, and vettes* says that it would be better to go with the tpi and get bigger runners,not longer but bigger in size for more air flow, intake, ect. he said this because on the TPIS charts*and out of all the engines he has built* it shows the mini ram has alot less hp and tq in the beginning. but then at around 6000+ rpms is where is gets its 100+ hp over a modified tpi set up. *well i hope u guy who know what chart i am talking about know what i mean.*
so what do i do.. go for the extra 100 hp and 100 tq but "wait" an extra 1000 rpms or get 300 lbs of tq @ 1500 rpms where as the mini ram is like in the 200's still.
novaguy.. i hope u read this. i havent seen u on for a while. but if i find u ill be chating with you.
Old Apr 24, 2001 | 09:59 PM
Mo's Avatar
Mo
there is a really good post around here somewhere talking about all the mini ram stuff and what not, try running a search for it
Old Apr 25, 2001 | 08:17 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Car = 1985 Z-28 w/ GM ZZ4 engine and LT4 "HOT" camshaft.
MiniRam Power = Blue and Green
TPI Power = Red. This is a FULLY upgraded TPI intake (AS&M extruded LTRs, *PORTED* Edelbrock Hi-Flo base, ported plenum.
Full details are here:
http://www.eecis.udel.edu/~davis/z28...MRwebpage.html
Long and short of it:
1) MiniRam makes 31 more hp and the TPI makes 38 more ft/lbs.
2) TPI Horsepower starts dropping after 4800rpms.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
[This message has been edited by TRAXION (edited April 25, 2001).]
Old Apr 26, 2001 | 10:53 AM
Beefy89's Avatar
Mini Ram.
Fast as a shark~~~~~~~~~~~~~~~~~ SAVE NAPSTER!!!
LT1Formula
20
Nov 14, 2015 12:02 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
