...dropped a socket in the runner...part 2
Old Apr 27, 2001 | 07:39 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Ive taken out the runners and the bolt is nowhere to be found..Should I go get a flex rubber hose with a magnet at the end or take the intake(base) off??Im afraid I might drop the duct taped magnet or it might get stuck there somehow..BTW whats the worst scenario..
Daz
Old Apr 27, 2001 | 08:04 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
Buy a telescoping magnet, they sell them at sears and lots of auto parts stores.
You could also buy...I don't know the proper name for it, it's a flexible shaft that has a three pronged claw on it.
If you can't get the socket out you have to pull the intake. I don't know what size socket it is, so it would either:
Worst case scenario, if you left it in:
A - screw up your intake valve, if it was too big to pass the valve
B- get sucked into the cylinder and screw up the cylinder wall, piston, valves, combustion chamber and possibly cause the conecting rod to bend a bit.
Find it and remove it, even if it means removing the intake.
Old Apr 28, 2001 | 11:19 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
use a snap on telescopoic magnetic pick up it will easily pull up a 3/8 drive ratchet and socket has a ;ot of power and its very thin to fit in small places
Old Apr 29, 2001 | 03:52 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Jed,
That tool is called an "Extractor Tool" by Snap On.....just FYI.....
Laterzzzzzzzzzzzzz
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
ramicio
Sep 28, 2015 01:18 PM
roysatikas
Sep 22, 2015 08:15 PM
