Street Fast Burn?
Old Nov 14, 2007 | 06:07 AM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Street Fast Burn?
I'm going to be building a 350 TPI for the street, so I'll be using a street cam along with factory TPI. I really like the fast burn heads, but would they work well on a street engine?
Old Nov 14, 2007 | 04:40 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: Street Fast Burn?
87TTops,
Yes the fast burn head is a good design and is very street able. Hope your getting a good deal on them. In the end it depends on what you want to accomplish with your car. More details would be appreciated.
Rabi c.
Old Nov 15, 2007 | 12:26 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You need to use the Vortec TPI manifold from Scoggin Dickey, because it uses the taller intake ports. Neither the stock manifold nor the aftermarket manifold will line up correctly with the Fast Burn heads.
Old Nov 15, 2007 | 08:14 AM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Right I plan on getting the SD baseplate. I'm not getting any deal on em, I just really want em and am willing to shell out the 1300 bucks. I want the aluminum for weight savings. I'd go with an aluminum block too if I had the money for an LS, but that's pushing it. I'm just wanting to build a mean 350tpi with road manners, so I can drive it daily. I'm still trying to figure out all this cam business though, I think I want something like 208int @ .05?
Old Nov 15, 2007 | 03:14 PM
Zipdrive's Avatar
208 deg at 0.050" lift is in the range of a stock 89 tpi cam. You need to define your goals more quantitatively and we could point you in a better direction.
Headers? Custom tuning? Auto/manual? deired operating range? etc.
Old Nov 15, 2007 | 04:10 PM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
I've already got headers, I'm keeping the 700R4, and I guess 1k-5k would really be all I'd need. I don't know anything about chip tuning, so I'd just assume to leave it stock, unless there's something wrong with that.
Old Nov 16, 2007 | 12:16 AM
Kevin91Z's Avatar
ZZ4 camshaft will work great with those heads and will let you use the stock chip, as long as you keep the stock 22lbs injectors.
Old Nov 16, 2007 | 04:13 PM
onfire's Avatar
Car: 88 Formula 350
The zz cam is a great cam, really street able, and holds an idle with plenty of vacuum for accessories. If you are around the southern cali area you can drop Kevin a line if you need to have your chip tuned.
Rabi C.
Old Nov 17, 2007 | 05:46 AM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Cool, I'll do that then. Know anyone in the CT area? I'm kinda far from California Would they do it at a machine shop? I think SLP or Callaway is right next door, would they do it?
Old Nov 17, 2007 | 03:26 PM
onfire's Avatar
Car: 88 Formula 350
87TTops,
No machine shop I know of does chip burning. Best bet is to check the regional boards for someone local to you. Just go down the list of links on the main message board page. There should be someone out there that would help you out. Good luck with your hunt man.
Rabi C.
Old Nov 18, 2007 | 05:39 AM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Kevin91z says I won't need tuning if I use the ZZ4 cam and 22lb injectors though. I'm all set then. Thanks for the help everyone.
Old Nov 18, 2007 | 12:35 PM
Kevin91Z's Avatar
I didnt need tuning when I ran the 22lbs injectors and the ZZ4 camshaft and ZZ4 heads. Advance your distributor from stock 6 degrees to 10 degrees to help.
Old Nov 18, 2007 | 06:03 PM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
Hey Kevin, I just noticed that the ZZ4 heads have 165cc intake runners. Does the fact that fast burns have 210cc runners mean this is a bad combo? I'm getting into this in another thread and now they're telling me fast burns are too big for street engines.
Edit: Nevermind, apparently the fast burn 385 crate engine is actually a zz4 with fast burn heads, so obviously the cam will work with the fast burns. Sorry for doubting you.
db057
Apr 28, 2019 07:45 AM
Nervous2
Oct 8, 2015 10:53 PM
85 Jimmy
Sep 30, 2015 07:56 AM
CatmanFS
Sep 19, 2015 09:00 AM
abray1
Sep 10, 2015 04:53 PM
