A/C delete
Old May 3, 2001 | 09:06 PM
DON 88T/A's Avatar
A/C delete
The a/c on my 88 T/A has not worked for a while,and I would like to get rid of it to cut a little weight down.
Is this an easy task?
I assume you have to run a smaller belt,or does someone make a dummy pulley in place of the original one?
Thanks for any help.
Old May 4, 2001 | 01:23 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Yea, you'll need the A/C delete pulley. I just put one on mine. the part # is 10055890 they run about 45 bucks.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, Accel box & coil, Taylor 409 wires, Fastchips custom chip, MAC sub frame connecters, Lakewood LCA & Adj. Panhard rod, SLP 2500 stall, 3.23 rear gears, 1LE aluminum driveshaft, white face gagues, and NOS!
Old May 4, 2001 | 10:59 AM
Beefy89's Avatar
$33 at www.gmpartsdirect.com
Fast as a shark~~~~~~~~~~~~~~~~~ SAVE NAPSTER!!!
Old May 4, 2001 | 12:49 PM
rondubbs's Avatar
just wondering how much hp this will create? or is it just a weight reduction thing?
Old May 4, 2001 | 02:11 PM
89FormulaL98's Avatar
is there some sort of firewall plate that i can buy to cover up A/C compont opening on the firewall? part #s?
Old May 4, 2001 | 02:32 PM
Kevin G's Avatar
Don fix your A/C, dont hack it like most others in GB LOL
Old May 7, 2001 | 01:55 PM
F22Raptor's Avatar
I need to get me that bracket too.
'88 GTA 350 Full of Leprosy (rust)
Check out my car here:
www.fortunecity.com/silverstone/brabham/42/
13.39@102.50 MPH
1.90 Sec ----- Best 60FT
104.23 MPH -- Best Trap Speed
AIM HIGH!
[This message has been edited by F22Raptor (edited May 07, 2001).]
Old May 7, 2001 | 06:16 PM
DON 88T/A's Avatar
Thanks for the input.
Not sure if I'm gonna do it...I've lived without it for awhile so I wouldn't miss it. That whoe setup must be worh some weight...
Besides in order to beat the GB crowd,sometimes you have to stoop to there level...LOL
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
