tpi conversion worth it?
Old May 7, 2001 | 09:46 PM
firbird's Avatar
I am thinking about converting my tbi into a tpi system i can get my friends tpi off his car because he is going to put something else on it. I was wondering if it is worth it for only 200 dollars and if i could take out all of the wires off of his car for the tpi without screwing any thing else up i know i can buy a wiring harnes but i am very low in money and what other things will i need?
Thanks alot
Old May 8, 2001 | 12:56 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
If you are taking out his entire system, that is, if he is going to a totally different setup, then you shouldn't have to buy anything unless something is bad. Get all the sensors, (MAF, IAT, knock) the ECM, and the entire harness if you can get it. Also make sure you get the fuel pump and fuel tank with the lines if you can.
If you want to buy a harness, I can tell you that there have been a lot of complaints on here about Painless Wiring's harness, that it's too short and connectors in the wrong spots, so I would buy the GM one. Hope this helps.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
[This message has been edited by Kevin Irving (edited May 07, 2001).]
Old May 8, 2001 | 03:15 AM
firbird's Avatar
thanks for the help
Old May 8, 2001 | 03:18 AM
firbird's Avatar
But why do i need the fuel pump and fuel tank with the lines is mine different from his? i just thought ours would be about the same.
Old May 8, 2001 | 07:56 AM
Car: 1985 Trans Am
TBI fuel lines can't hold the pressure that is required by TPI, and I believe that the mounting on the tank for the fuel pump (since the fuel pump is different also) is different than it is for the TBI
Kevin Irving
Old May 8, 2001 | 08:05 AM
Scott C's Avatar
All you need is a new intank fuel pump. The tanks are the same and the lines are the same (except possibly at the front of the engine where the fuel rail lines connect). TBI fuel pump only flows 9-15psi stock, where TPI flows up to 50+psi.
Old May 8, 2001 | 02:00 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Yep, TBI has an intake pump, so you just need to swap pumps out, and change the fuel sock on the end of the pump while you're in there. Also change the in-line fuel filter. Mine was a perfect swap in my truck.
As far as fuel lines, they should be metal for the most part, your ok. For those places where its a rubber hose on the supply side, be sure its high psi hose for at least 75-100 psi to be safe.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
79 TA 6.6l - all original stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, 12.40 @ 108 w/1.79 60'
95 Trans Am Conv.- LT1
1992rs/ss
Jan 31, 2025 05:10 PM
lt1z350
Aug 28, 2015 05:57 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
