TPI 5.0 - 1991 Z28
Car: 1987 IROC-Z
Transmission: 700R Auto
TPI 5.0 - 1991 Z28
I have a 91 Z with a non-modified 305.
I am in the process of having a 4.10 Eaton POSI Disc rear installed. So to get the best out of this I need to modify my engine (had a 5.7 but my buddy just killed his engine in a '79 Z) He picked the parts up for me so.....
Anyway what can I do to modify my exisiting engine to get the most out of my new rear. (Oh for those of you saying why did a get a rear like that, it was almost new and cost me $150).
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: TPI 5.0 - 1991 Z28
a t-56 swap would work well with those gears
You can even keep some gas mileage.
You can even keep some gas mileage. Banned
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
i agree either a manual or build youre 700 with some nice stall.. i still vote cam it!! and dont forget suspenion goodies.. u do want that bad boy to hook up a little bit.. maybe??
Car: 1989 T/A
im going to install crane cam 2032.. its perfect for an lb9.. it should be done by may so the wait is on.. im also going procharger..as far as suspension goes i like my umi peices there identical to hotchkins at 1/2 the price. also throw some headderon that z.
Car: 1989 T/A
and for a tranny rebuid there's a shop called freddy brown. there in my hometown. theyve been building hi po tranny's for 40yr's there the best boiled and coated cases and everything soup to nuts. s-k speed stocks them as well. they also have a website.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
steep gears for a TPI!!!!
BIG cam/ good flowing heads/ and (i have never said this before bc i dont believe it) RIP OFF THE TPI!!
the 4.10s are goiing to get your outa the hole and ur powerband in quite a hurry, switching to a better form of intake will prob net more power since your gona be reving this thing to the moon. i dont think ur shift points are gona be 5000-5200 with that TPI lol.
Car: 1987 IROC-Z
Worst come to worst I will trade someone my gears for a 3.73!!!
Car: 1989 T/A
it depends, on a few things mostly upwards of $1700, but youll have a tranny that will deal with any future combo. u will ever want to run.
Iroc8t8
May 4, 2026 08:09 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Sanjay
Aug 12, 2015 03:41 PM
