General TPI
Old May 8, 2001 | 09:54 PM
RealDeal's Avatar
General TPI
Hey, i know nothing about the inards of engines and i'm slowly trying to learn, but could someone basically explain Tuned Port Injection to me. Keep in mind i know very little about the engine of a camaro. I have a '91 RS V6 so how would it relate to me, if at all. I know this is probably a waist of time for a lot of you, but any help would be appreciated. lol, i feel like a child, but i really want to learn about F-Bodies. Thanks
Old May 8, 2001 | 10:24 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
All u have to do is look in the Tech Articles.
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old May 8, 2001 | 10:45 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
Two OUTSTANDING articles here..... http://www.racer-x.f2s.com/proc/tpi1.htm
and
http://www.racer-x.f2s.com/proc/tpi2.htm
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old May 9, 2001 | 12:41 AM
Yarnboy's Avatar
Great articles aside from the fat that he says porting the MAF is a good idea and the TB bypass is a bad idea..I feel the same way except backwards. And, I think he believes TPiS too much..Esp. with the AFPR claims..Tt was written in '98..so things may have been different back in the day
  • Red '88 IROC 5 Speed 305 TPI w/3.08
  • Dual Friction Stage III Centerforce Clutch
  • Accel 300+ Racing Ignition
  • Accel 300+ Pro Sleeve Plug Wires
  • AC Delco Rapid Fire Plugs
  • Flowmaster Force II 3 Chamber Cat Back Exhaust
  • Hypertech Chip
  • Hypertech Airfoil
  • Gutted Air Box
  • Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
  • Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
  • Best 60' 2.163(Florida)
  • TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
  • Aluminum Driveshaft (Installed after Maryland run)
mustangman65_79
Aug 31, 2015 12:08 PM
Thaney9
Aug 29, 2015 03:16 PM
ezobens
Aug 19, 2015 10:29 PM
Jake_92RS
Aug 17, 2015 09:42 AM
Sanjay
Aug 12, 2015 03:41 PM
