Lose wire to injectors
Old May 8, 2001 | 04:48 PM
smythe87GTA's Avatar
Problem w/my 87 GTA 305 TPI: The other night as I was driving it started stalling. Brought it to the mechanic, this is the report: I have a lose wire in my injectors. As a result, they are getting no power, so they won't work.; no fuel to my engine, won't run. My question is this: Has anyone had this happen to them, & how long does it take to fix?
Old May 9, 2001 | 07:01 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I had a bad injector that was going to ground when it got hot. It stole voltage from all my other injectors, not allowing the car to start when hot. If you have a loose wire inside the injector plug, any good GM Tech should be able to pull the stock connector out of the plug and resolder a new one in, or just cut the entire plug off and solder a new one on. Should be very simple. However, one bad injector plug should not cause your car not too run after it's already started. I can unplug an injector while my car is running no problem.
Good luck.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
midge54
Dec 27, 2019 04:14 PM
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Bryan F
Aug 18, 2015 02:28 PM
