Is there a way to bypass the MAF Sensor
Old Nov 23, 2007 | 10:56 PM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
Is it all necessary to have a MAF sensor. My car passed Cali emmisions easily without it. I just prefer to run a K/N at the Throttle body if I can.
Old Nov 23, 2007 | 10:58 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: Is there a way to bypass the MAF Sensor
convert it to Speed Density
Old Nov 24, 2007 | 02:42 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Edit: Also if maf not functioning correctly or not present, the ecm uses RPM and TPS instead.
Old Nov 24, 2007 | 10:52 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
TPS??
Old Nov 24, 2007 | 11:20 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
TPS is throttle position sensor.
use this site for acronyms: http://www.acronymfinder.com/
Old Nov 25, 2007 | 11:21 AM
76ANTHONY's Avatar
how is this done? i also have an 86 iroc and would like to do this
Old Nov 25, 2007 | 11:25 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Good grief.
Old Nov 25, 2007 | 03:33 PM
Axle/Gears: 373s
I hope there is a step by step on this.... Maybe someone has done this.
Old Nov 25, 2007 | 03:47 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
go in the tech section here in the other subforums. one guy just posted about running a MAF car without MAF and runs it daily. its titles swirlport myth busted i think.
i figured id be nice and find it then link you check the 2 links he put up thats where it explains how its mafless. https://www.thirdgen.org/forums/tech...wirl-port.html
Last edited by vipershark11; Nov 25, 2007 at 03:49 PM. Reason: Automerged Doublepost
Old Nov 26, 2007 | 01:14 AM
Kevin91Z's Avatar
And here is the tech article on swapping from MAF to speed density:
http://www.eecis.udel.edu/%7Edavis/z28/ecm_swap_730/
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Formula8r89
Sep 22, 2015 04:24 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
