ECM OR E-PROM
Old Nov 27, 2007 | 08:20 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
ECM OR E-PROM
i have an 1987 i roc-z and for the longest time i've had a check engine light on in my car is is a code 36 and recently pulled the motor and rebuilt it and when i did this i pulled apart the wiring harness and checked for any broken wires and shorts but i only found 1 but that didn't fix it , i have changed all the mass air sensor relays and mass air sensor with new gm replacement parts no change so the only thing left is the ECM or E-PROM , now code 36 is burn off relay curcuit and i am wondering if the ecm itself controls the maf burnoff relay curcuit or does the e-prom contain the curcuit for the maf burnoff, i kno that the e-prom contains all the peramitters for the emissions controls and the fuel injection and the burn off curcuit does nuthing when the engine is running only when you turn it off . so if anyone knows if i just have to replace the ecm or the e-prom to fix this thanks .
Old Nov 27, 2007 | 09:15 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: ECM OR E-PROM
Check the MAf connector real close. On mine, one of the pins would slide up into the connector when I connected it to the maf. When I un-plugged it, the pin would slide back down in position and look normal. Took me a couple of weeks to find that one!
It highly unlikely the ecm/prom is the problem.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
