HP/TQ Guestimate....
Old May 16, 2001 | 05:54 PM
Bob M's Avatar
I'm in the market for a torque converter. I don't know what my peak hp and tq numbers are or where they fall. I was hoping that maybe someone here could help me figure it out. Maybe someone with desktop dyno?
Here is the jist of my combo:
-383 w/flat top pistons (11.67-1 compression)
-Edelbrock 6085 heads (out of the box)
-zz9 camshaft w/1.6 rr's
(212/226@.050 .515/.525)
-Edelbrock TPI intake (out of the box)
-SLP runners
-Ported plenum
-52mm TB
-Stock 22lb injectors
-4.10 gears
Any help or even advice on picking the correct type of converter would be GREATLY appreciated. TPIS Said that "I'm making peak power at 4,500rpms and should stick to a stall speed of 2000-2400" Does this sound right?
Bob
Old May 16, 2001 | 07:01 PM
poncho9789's Avatar
I just ran you engine on desktop dyno2000 and it says 409hp@5500 rpm and 450fp@4000 rpm.These numbers are goten from running the cam strait up. You can use these ratings as a guide and from experance they are pretty close.
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil, bosch platnum plugs, this car is currently under rebuild and restoration.
Old May 16, 2001 | 07:06 PM
poncho9789's Avatar
sorry I forgot to enter your 383 and comp ratio
HP 430@4500
TQ 491@4000
Old May 16, 2001 | 07:08 PM
poncho9789's Avatar
if you can e-mail me the numbers on your cam card and I can try to nail it down more accuratly. I would like to get the no. off the cam card for my own files anyway.
Old May 16, 2001 | 07:39 PM
Bob M's Avatar
Thanks!!! Let me dig out my card.... I'll post the specs in a few
Old May 16, 2001 | 07:51 PM
Bob M's Avatar
Here are the numbers as they appear on the card:
Duration at .050 -- 212/226
Lobe Lift -- .3229/.3466
Lobe Separation -- 112*
Seat Duration -- 270/282
Gross Valve Lift -- .484/.520 (1.6=.515/.554)
Degree Intake Lobe -- 108 ATDC
Seat timing Int: 0 BTDC: 32 ABDC: 108
Seat timing Exh: 48 BBDC: 3 ATDC: 116
Thanks again for your help!!!!!
BOb
Old May 17, 2001 | 04:59 PM
poncho9789's Avatar
if you can recheck your camcard and make shure it is right I am coming out with some strange readings with the numbers you posted.
Old May 17, 2001 | 05:31 PM
Bob M's Avatar
Ok, see if I can get this to work... Here's the card that came with the cam.
Old May 17, 2001 | 07:14 PM
poncho9789's Avatar
desktop dyno says that your motor will make 508tq @ 3500
428hp @ 5000
those numbers are running the cam at 3* advanced.
those are great numbers, but I would not take them to heart they are numbers from a computer not actual numbers you will actually produce.
Good luck
thats one hell of a engine.
Old May 17, 2001 | 07:51 PM
Bob M's Avatar
Thanks for the help! Yeah I know those numbers are high but its a starting point Hey, could you save and email me the .dyn file for that? I got a copy of dd2000 today! My email is bobden13@erols.com
So far the engine has been in the car for a year now. The transmission has been a problem from the start so I haven't been able to really enjoy it. I got a new tranny under my warranty, but its "remanufactured to oem spec". I'm gonna get some extras for it as soon as my tax refund gets here
mess21
May 11, 2004 05:51 PM
SweetS10v8
Dec 9, 2003 01:03 AM
gruveb
Dec 6, 2002 08:51 PM
Makaveli
Nov 3, 2002 09:54 AM
bzznczzn
Sep 18, 2002 11:03 PM
