92 TPI, what sensor controls the fan?
Old Nov 30, 2007 | 05:55 PM
SatisTraction's Avatar
i swapped a COMPLETE 92 tpi engine into a85 truck. the fan works when i run the codes but it never comes on as the truck heats up. i am assuming that i missed a sensor or it is bad. where is the temp sensor for the fans?
thanks
chris
Old Nov 30, 2007 | 06:03 PM
Re: 92 TPI, what sensor controls the fan?
i am looking for the PRIMARY fan sensor. that is is the only one that i am using.
Old Nov 30, 2007 | 06:20 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
thanks
chris
The ECM turns it on through a relay.
Old Nov 30, 2007 | 06:59 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Some tpi set ups used two fans. One controled by the ecu and the other controlled by a temp switch in the passenger side head.
Old Nov 30, 2007 | 07:27 PM
i am looking for the sensor that controls the ECM. i have a dual fan set up but i am only using the primary.
Old Nov 30, 2007 | 10:38 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Then you'll be looking for the CTS (Coolant Temperature Sensor) on the front of the intake manifold under the TB. The ECM uses this sensor to detect the engine temperature. Once the temp reaches certain point (I believe it's around 235*F for the TPI), it turns on the primary fan via the relay mentioned above.
Hope this helps.
Lou
Old Dec 1, 2007 | 08:20 AM
235, damn that is HOT. does the other one come on sooner?
Old Dec 1, 2007 | 10:53 AM
BigBadLou's Avatar
Engine: TPI
It might be 230*F, I do not remember exactly.
Our cars run at 220 all day so 230 isn't that hot considering.
Lou
Old Dec 2, 2007 | 10:07 AM
well i decided to put a hypertech 185 switch in the head. I am going to run it as the primary and the CTS sensor as the back up. that should keep the truck cooler.
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
