Aftermarket Throttle Bodies
Old Dec 1, 2007 | 07:44 PM
Aeroking's Avatar
Car: GMC Syclone
Engine: 4.7L V6 Turbo
Transmission: Built 700R4
Axle/Gears: 3:42 AWD
First off, its not for a FBod, its for my truck.
The stock throttle body is a rarely made third gen TB, the linkage is a little offset from the standard 85~92 TPI.
Off the shelf BBK and Holley TB's aren't suitable for my application.
Any suggestions on custom TB builders??
I'm looking for a twin 58mm unit. And Yes i do need a larger TB.
Old Dec 2, 2007 | 09:03 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Aftermarket Throttle Bodies
This is ThirdGen.org. Try searching Google for truck forums.
Old Dec 2, 2007 | 09:07 PM
Aeroking's Avatar
Car: GMC Syclone
thanks alot, but being a TPI base TB, are there any 3rd Gen vendors which do custom TB work?
Old Dec 2, 2007 | 09:27 PM
I'm not aware of any. But you might give TPIS a call... I believe they have a large machine-shop and do some custom work. Plus they specialize in 3rd gens, so they may know a lot about your TB setup.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
