TPI gurus, need some intake setup advice
Old May 20, 2001 | 08:34 AM
formul8!!'s Avatar
Car: 2004 GTO
I have a chance to buy some AS&M runners, fully ported plenum and a 53mm throttle body.
My current setup is this:
1989 TPI L98
-Edelbrock lower manifold
-24# injectors
-AFPR
-Modified MAF
-SLP cat back exhaust
-hi flow converters
-stock heads & exhaust manifolds, stock cam
-I will be rebuilding the trans with a SLP torque converter.
Will the long tube runners and 52mm T/B be too much for the stick heads & manifolds?
I don't want to add these parts now and loose a whol bunch on the low end because they flow more air than the rest of the system. I do plan on heads,cam and headers in the future, but not for a while.
Any advice?
Thanks in advance
Old May 20, 2001 | 06:52 PM
vortech305's Avatar
Im guessing u have a 350 so in my opinion u can use the 52mm throttle bodie and the AS&M runners, they help promote torque. Like i said if u modify the exhaust, u must modify the intake. U wanna help your motor inhale and exhale. I have those mods on my 305, so go for it.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old May 20, 2001 | 10:38 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Those parts shouldn't hurt you at all. Sounds like a good addition
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old May 20, 2001 | 11:04 PM
90 Z28SS's Avatar
Man Dylan , if were you I would pass and FIX the tranny man and get a converter . Your gonna get more from that . Personally I would not do the TPI till I could do it all at once . Add a set of 3.42 gears to the tranny/conv. combo and you'll really get a nice gain
Derek 90 IROC 5.7
Mods: All the usual bolt ons siamesed base , 2500 stall , 373's , SS hood ,big and littles , lotta reduced weight. Stock heads/rockers , cam ,runners , chip and TB
Best Et: 13.12@101 ...1.701 60 ft.
Terrell351
Jun 13, 2021 01:13 PM
masonta
Aug 31, 2015 10:14 PM
jbd1969
Aug 17, 2015 07:06 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
