ZZ3 cam in a 350
Old May 15, 2001 | 04:37 PM
jmon92conv's Avatar
ZZ3 cam in a 350
In my search for a cam, I am thinking about the zz3 cam. Does anyone here run it and how do you like it? What setup do you have? I will be running a 350 with ported plenum, Accel base a few other minor goodies with 3.42's and a 5-spd. Do yo think it wil be OK, or should I go with something else for a daily driver with 300hp. At least that is the goal
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Old May 16, 2001 | 02:48 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, I used it in my previous engine, its a great cam. But if you are using the stock heads, you'll need new valve springs to handle the lift.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 16, 2001 | 08:02 PM
jmon92conv's Avatar
I am using alum heads and I can get the springs. What kind of power did it make, how did it feel, and did it pass emmissions(sp)? I autoX this thing, so i would like good response.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
Old May 16, 2001 | 08:57 PM
Kevin91Z's Avatar
It made 280 HP and 380 TQ to the wheels with a ported stock TPI intake, L98 aluminum heads, SLP 1 5/8" headers. I dont know if it passed smog, I pulled it out when I over revved it at the track and put in a stock engine to smog with. But it should have passed smog easily.
Old May 16, 2001 | 09:09 PM
jmon92conv's Avatar
sounds good. I might try it, hell, if I don't like it, I can sell it. Thanks a bunch
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
Old May 16, 2001 | 09:38 PM
DSouthern's Avatar
Jeremy,
I'm running the ZZ3 cam and like it a lot. I have not dynoed the car so don't have any numbers for you put it is much faster than the stock setup. I passed California smog with no problems, although I understand Los Angeles has a different test than I have here in Central Calif., but I believe it would pass that test as well.
As Kevin said you will need different valve springs to handle the increased valve lift. I used the GM springs that come with the LT4 Hot Cam kit. These springs are larger diameter than the stock springs and required machine work. Good luck!
87 GTA, 350 TPI, auto, 3:27 gears, rebuilt engine, ZZ3 cam and valve springs, pocket ported stock heads, edelbrock intake, TPIS air foil, AFPR, high flow air cleaner, modified stock air canister, relocated air intake sensor, tb bypass ported plenum, modified MAF (screens removed), edelbrock headers, hi-flo cat, flowmaster muffler, stock chip.
Old May 17, 2001 | 07:24 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You definatly need machine work for bigger springs and cut the valve guide down.
Old May 19, 2001 | 11:16 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
for $110 TPIS has drop in springs for l98 aluminum that handle .550 lift.part number 700-132
Old May 19, 2001 | 12:08 PM
jmon92conv's Avatar
Thanks Pete. The springs I have will handle 510 lift, which is what the zz3 cam has, I might try these until something goes wrong. I really don't plan on pushing the motor real hard.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
Old May 19, 2001 | 04:54 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Jeremy-
I've talked to Kevin alot about this too. I bought a ZZ4 cam I bleieve (same or different) and am bulding an L98 with ported plenum, ported iron L98 heads, gasket matched everything, Edelbrock TES headers, 3" exhaust, holley AFPR, holley/walbro 255lph pump, coil, wires, K&N, flows, 6-spd, and 4.10's. I'm hoping for a low 13 with good traction. Its all in the works right now. I already have the motor, cam, headers, pump, etc, but I need to re-ring the motor and turn down the crank. I'm also trying to find the correct springs so I don't need machine work. Which should I run? Anyone? I'm also contemplatin some 1:6I and 1:52E roller rockers. Anyone have any thoughts? Thanks, and good luck!
'91 GTA:
www.fbody.com/members/91WS6GTA
Old May 20, 2001 | 01:31 AM
JoelOl75's Avatar
K-Motion I think 750's from jegs. They are stock diameter, made of H-11 tool steel wire and I have 20,000 miles on mine with a zz cam.
they are around $125.
Old May 20, 2001 | 10:42 AM
jmon92conv's Avatar
I am also considering 1.6/1.52 but I haven't done enough reading on it. any responses on this would be nice. 91GTA, we have Very similar motors, keep in touch on the progress.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
Old May 21, 2001 | 04:16 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
As far as valve springs go, www.fastvalves.com sells stock diameter springs that will go to .600 lift. I have a set, not installed yet. You have to watch the installed height. I need longer valves, offset keepers, shims, and custom pushrods. It does get expensive.
Joshua Johnston
1991 Z-28
Flowmaster
K&N
305 / 5spd. (Temporary)
Old May 21, 2001 | 09:18 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Jeremy-
Thats cool! They do sound little similar. I hope mine just gets done this summer. I may scratch the roller rocker idea for costs right now, but still need the RIGHT valve springs. Give me a holler at: heizemen80@hotmail.com
*Hope to hear from you soon! Later
'91 GTA:
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theshackle
Aug 22, 2015 06:52 PM
