TPI running rough, Frustrated.
Old Dec 4, 2007 | 01:40 PM
rv34's Avatar
Car: 1992 Trans Am
Engine: 355
Transmission: M21
Axle/Gears: 3.70 9 bolt
I am having a problem, I need help. It misses, runs like crap, wont idle, falls on its face at 4500 rpm, pops out of the intake and exhaust (Small exhaust leak). If I work on it at night, I can get it to run ok, and start. But then the next morning it will not start, act like it is too advanced, and not start. If I play with the distribtor, i can get it to fire after a little. But then again it still runs very bad. I have put on: Cap, rotor, plugs, ignition module, different set of used good (I thought where) wires (getting new ones today, light show under the hood.) good 43lbs of fuel pressure, injectors tested good, and tons of cursing. I can not figure this out. I am a carb guy, so please guide me along, and I will try my best. I am going to light it on fire. Also, it has a new knock sensor, and starter. It pulled code 43. But for some reason my scanner will not go into Live data, so I can not see sensor readouts.
Thank you for any help.
Old Dec 4, 2007 | 02:00 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: TPI running rough, Frustrated.
Well a code of 43 is for a Electronic Spark Control and it could back off your timing if its faulty for some reason. Some times the sensor might be bad even if its new especially if its from pep boys or some place like that.
I just had the same thing happen with my other car when the fan switch went out. Went down to the pep and got a new one but it wouldn't kick on until it gets real hot and the dummy light comes on. Just a thought.
Rabi C.
Old Dec 4, 2007 | 02:01 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Did you try another distributor?
Old Dec 4, 2007 | 02:05 PM
rv34's Avatar
Car: 1992 Trans Am
Engine: 355
Transmission: M21
I was also thinking dizzy, now that someone else says that it is possable, I will try it tonight.
Thanks guys!!!
I can test the knock sensor right?
Old Dec 4, 2007 | 09:56 PM
rv34's Avatar
Car: 1992 Trans Am
Engine: 355
Transmission: M21
Thank You everyone!!! It was the dizzy! It runs much better then it ever has! Thanks!
Old Dec 4, 2007 | 10:06 PM
hawkins1017iroc's Avatar
Car: 87 iroc
Engine: 5.7 TPI
Axle/Gears: 3:27 posi
while you guys are teaching on the subject my tpi 5.7 is surgeing at idel. it has new wires cap button and plugs..
Old Dec 6, 2007 | 10:56 PM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
I had a surging at idle problem , it was the egr . Have you checked for any codes ?
Old Dec 7, 2007 | 01:38 PM
91350rs's Avatar
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
check to make sure you have the right knock senser. a tpi motor knock senser should read around 35000 ohms. a tbi would have about 100000 ohms. i had that problem
Old Dec 17, 2007 | 02:14 PM
Car: 87 iroc
Engine: 5.7 TPI
thanks i will try the knock sensor and the egr.
customblackbird
Aug 15, 2021 10:16 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Sherpajames
Aug 7, 2015 06:56 PM
