ZZ3 block with Fast burn heads????
Old May 23, 2001 | 06:05 PM
Drewcifur's Avatar
Car: 1989 Firebird Formula
Engine: 350 ZZ3
Axle/Gears: Stock
Is this a possible combination? From what i understand they are probably one of the best heads out there. Anyone using them?
89 Formula 5.7L
ZZ3 with some good mods
Old May 23, 2001 | 08:22 PM
R.O.B.'s Avatar
Those heads will bolt up with no problems to the block. Your intake will be another story, Fastburn heads are Vortec style.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old May 23, 2001 | 08:35 PM
Drewcifur's Avatar
Engine: 350 ZZ3
Axle/Gears: Stock
So ur saying they can't be used with tpi systems?
Old May 23, 2001 | 09:26 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
there is enough room to port an edelbrock base to match the higher ports of the fastburn heads however you will have to drill new holes for the bolt pattern to match
Old May 23, 2001 | 11:12 PM
Drewcifur's Avatar
Engine: 350 ZZ3
Axle/Gears: Stock
Ahh i see now i know why nobody is running that setup. Thanks man
Old May 24, 2001 | 12:28 AM
Tas's Avatar
Tas
Holley is supposed to have a EFI intake for Vortec type heads: L31(Vortec 350), L30 (Vortec 305), Fast Burns, and Edelbrock E-tecs. I put the PN into www.summitracing.com and it came out $435.69 for the bare intake.
http://www.holley.com/HiOctn/ProdLin.../9901-110.html
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old May 24, 2001 | 01:19 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Uhm... Fast Burn heads have both bolt patterns cast into them. They will bolt up. However the intake port shape is different, like was discussed above.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old May 24, 2001 | 11:22 AM
Drewcifur's Avatar
Engine: 350 ZZ3
Axle/Gears: Stock
Yeah, thats a shame,i really wanted to see if i could use them with my tpi setup. Guess i'm gonna just port my zz3 heads.
Old May 24, 2001 | 11:58 AM
camaro6spd's Avatar
um...can't you match the ports??
Old May 24, 2001 | 01:40 PM
Drewcifur's Avatar
Engine: 350 ZZ3
Axle/Gears: Stock
So if i port the edelbrock tpi base to fit the fast burns' different port size it will bolt up no problem. Would that be a hard job for a machine shop to match the port size?
89 Formula 5.7L
Old May 25, 2001 | 07:28 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
The tops of the runners extend beyond the tpi intake casting.
This would aluminum fill welding the intake and seriously grinding the ports upward. It could be done, but for a machine shop... Expect to pay alot!
Jake_92RS
Jan 28, 2020 10:37 PM
Fast355
Dec 2, 2016 06:33 PM
MoJoe
Sep 24, 2015 09:12 PM
hayesaw0210
Aug 23, 2015 11:15 PM
lakeffect2
Aug 23, 2015 08:44 AM
