TPI rebuild ..
Old Dec 6, 2007 | 08:28 PM
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
TPI rebuild ..
gotta 91 305 tpi w/ the 5 speed ..
blew a head gasket two days ago and started tearing it down today ..
i cant believe this motor even ran ..
pulled the dist. cap .. 1/2" of rust sittin in it .. all the points rusted, and the ignition module looked like it had been to hell and back ..
pulled the valve covers .. atleast 3/4" of sludge around all the rockers ..
and two of the coolant temp sensors were snapped off ..
im going to pull the motor tommorow .. and fully rebuild it .. then put a edelbrock cam in it .. new distributor, 8mm wires, e3 sparkplugs, gear driven timing belt, and some other stuff ..
this car went fast when i drove it .. and im waiting to see how many horses i gain from a rebuild and cleaning it up ..
Old Dec 11, 2007 | 02:14 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: TPI rebuild ..
I would search the forum. There are better cams out there than Edelbrock.
Just my 2 cents.
Old Dec 11, 2007 | 03:32 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Re: TPI rebuild ..
Yes - Call Comp or Crane cams.
We've all told you this in the 40 other topics you've made dealing with this same situation.
fbirdroller
Sep 2, 2015 10:27 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 10, 2015 08:42 AM
hokis
Aug 9, 2015 03:57 PM
