MAF to MAP, is VATS going to get in the way?
Old May 26, 2001 | 08:37 AM
S10Wildside's Avatar
If a speed density ECM has VATS, will that give me trouble when converting from MAF to MAP? Do all speed density ECMs have VATS?
1982 S-10 Wildside
355 TPI, Accel High-Flow Intake, Ported Plenum, Arizona Speed & Marine Runners, TPIS AFPR, Edelbrock BBK 52MM Throttle Body, 1993 Typhoon Drivetrain
Old May 26, 2001 | 08:49 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The ECMs don't, its the PROMS you have to use that do. You can disable the VATs in the PROM chip by having it reburned or buy one with it disabled. Or you could just "retrofit" it into your car. Its a good Theft Deterrant.
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
Giocio
Oct 1, 2015 12:20 PM
aaron7
Sep 30, 2015 09:15 AM
